How does Oudie IGC derive TAS and Wind? Especially when there is no thermalling. It does not have Ptot/Pstat input and does not have heading info.
The TAS (5 bytes) and GSP (5 bytes) are recorded in the *.igc file --in the B-Record, as configured by the I-Record. Also--quantities TRT and VAT are recorded. What is that? Thanks |
At 21:53 17 December 2016, Hartley Falbaum wrote:
How does Oudie IGC derive TAS and Wind? Especially when there is no thermalling. It does not have Ptot/Pstat input and does not have heading info. The TAS (5 bytes) and GSP (5 bytes) are recorded in the *.igc file --in the B-Record, as configured by the I-Record. Also--quantities TRT and VAT are recorded. What is that? Thanks TRT -Track True. Three numbers based on degrees clockwise from 000 for north VAT -Compensated variometer (total energy/NETTO) vertical speed in metres per second and tenths of metres per second with leading zero and no dot (".") separator between metres and tenths. Valid characters 0-9 and negative sign "-". Negative values to have negative sign instead of leading zero |
On Saturday, December 17, 2016 at 4:53:59 PM UTC-5, Hartley Falbaum wrote:
How does Oudie IGC derive TAS and Wind? Especially when there is no thermalling. It does not have Ptot/Pstat input and does not have heading info. The TAS (5 bytes) and GSP (5 bytes) are recorded in the *.igc file --in the B-Record, as configured by the I-Record. Also--quantities TRT and VAT are recorded. What is that? Thanks Thanks--- Found this Oudie was connected to an S80. So--mystery solved. |
Oudie 5.19 Bug | Lauren | Soaring | 3 | June 4th 14 06:57 PM |
Oudie | fredblair | Soaring | 0 | June 13th 12 06:56 PM |
Oudie | Peter von Tresckow | Soaring | 2 | December 18th 11 01:31 PM |
Oudie | Steve Hunt | Soaring | 2 | July 8th 11 12:19 AM |
oudie | Steve Hunt[_2_] | Soaring | 0 | July 7th 11 08:58 AM |
