Glider Maintenance - Fuselage Rotisserie
Old January 6th 17, 01:48 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Glider Maintenance - Fuselage Rotisserie
After years of wandering around northern NJ temporarily occupying the workshops and garages of club members who were kind (or stupid) enough to loan out space, Aero Club Albatross (ACA) finally has a shop of our own at Blairstown airport. As the Refinisher in Chief, I'm building out the infrastructure bit by bit to make sure we are well equipped for future projects. I'm looking for good examples of fuselage fixtures, especially ones that allow for the whole fuselage to be rotated at least 90 degrees either way from vertical.
So, does anyone have examples of a fuselage rotisserie with some photos you can share? We already have a cradle/sling as well as solid stands. We also have used a hoist from the ceiling in the past. Each of these presents some challenges when painting, so we're looking to start fresh. Any pics, sketches, or ideas would be appreciated. We have world class fabricators and machinists in our club, so we can go top tier - no 2x4s and bungee cords. You can email me at erik dot h dot mann @ gmail dot com
Erik Mann (P3)
Old January 6th 17, 04:10 PM posted to rec.aviation.soaring
Contact Paul Gaines at alphazulucomposites dot com. At an SSA convention years ago, I saw a "glider roller" he built, and there is a photo showing one at his shop in Kingman, AZ. Not enough detail to build one, but at least a start.
Old January 6th 17, 04:52 PM posted to rec.aviation.soaring
Erik Mann (P3)
Someone showed some photos of an "octo roller" made from 2 sheets of plywood that picked up front lift pins and rear pins using arms. 8 sided allowed easy rolling to desired position.
I don't remember where I was it. Maybe in the VSA group.
None of these is easy to spray around. For that I hang and tilt 15 degrees or so with a gallon can hung on an arm off lift pins.
FWIW
UH
Old January 6th 17, 06:23 PM posted to rec.aviation.soaring
Jonathon May[_2_]
wor=
loan=
Bla=
infras=
projects.
that
f=
rom vertical. =20
=20
y=
We=
presen=
p=
fabrica=
bunge=
=20
Erik Mann (P3)
plywoo=
allowed
easy rolling to desired position.=20
degrees
FWIW
UH
Somewhere there is a video of a Belgian repair shop rebuilding a broken
Arcus
They have a rig with 2 steel rings and longerons that pick up on the wing
mounts and Cardinal points.they set it to a second new arcus in it and set
points ,then locked it up and fitted the 2 half s of a Brocken arcus to the
same points and re build the bit in the middle
Awesome video if you can find it just build a copy
Old January 6th 17, 08:06 PM posted to rec.aviation.soaring
Jonathon May[_2_]
wor=
loan=
Bla=
infras=
projects.
that
f=
rom vertical. =20
=20
y=
We=
presen=
p=
fabrica=
bunge=
=20
Erik Mann (P3)
plywoo=
allowed
degrees
FWIW
UH
Sorry my las post was inaccurate ,it was a soaring cafe piece
http://vimeo.com/60497114
Jon
Old January 6th 17, 08:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Erik Mann (P3)
HP-24 project photo pages; 18 May 2014 - plywood octogon. https://www.facebook.com/20093135495...549952/?type=3
Feb 26/2015 - Great and Terrible Infinigon. https://www.facebook.com/20093135495...type=3&theater
Always a great browse.
Old January 6th 17, 08:49 PM posted to rec.aviation.soaring
Bob Kuykendall
In my shop, we have two rollover rings:
* An octagon made from two plies of hardware-store 2x4s, where the plies overlap at the joints. I also made a roller stand for it, but we mostly just set one of the eight edges down on the floor.
* An infinigon (my daughter's term) we made out of a 48" diameter welded steel hoop salvaged from an abandoned kid-sized trampoline. We use it with the roller stand I originally made for the octagon.
In both cases the hoop attaches to the forward lift pin fitting, which by definition can carry several times the non-lifting weight in pretty much any direction. There is also a strut that attaches the hoop to one of the two aft lift pins to prevent the hoop from rotating around the axis of the forward lift pin fittings.
For the aft fuselage we generally just rest the tailboom on a padded sawhorse just forward of the vertical fin. We also have a sawhorse with two rubber wheels for this duty as well. For a finished glider, we girth the tailboom with masking tape where the roller runs so it doesn't scuff the paint.
There are photos in the HP-24 facebook page albums, probably back around October 2015 when we were painting 24-03.
Thanks, Bob K.
https://www.facebook.com/HP-24-Sailp...-200931354951/
Old January 6th 17, 08:53 PM posted to rec.aviation.soaring
Bob Kuykendall
Thanks, you beat me to it! --Bob K.
Old January 6th 17, 09:06 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
wor=
loan=
Bla=
infras=
projects.
that
f=
rom vertical. =20
=20
y=
We=
presen=
p=
fabrica=
bunge=
=20
Erik Mann (P3)
plywoo=
allowed
degrees
FWIW
UH
Arcus
Here is that video
https://vimeo.com/60497114
Colin
Old January 6th 17, 09:09 PM posted to rec.aviation.soaring
Papa3[_2_]
Yeah, I had seen this. Still salivating: https://vimeo.com/60497114
looking for damaged unflyable tandem glider fuselage and canopy touse as body for a 3 wheeld electric car. [email protected] Soaring 4 October 25th 15 03:18 PM
Engine maintenance of a motor glider kd6veb Soaring 0 October 13th 13 05:57 PM
German registered glider maintenance: help with LBA doc needed Ludovic Launer[_2_] Soaring 3 July 19th 08 10:43 AM
Looking for a fuselage Jay Honeck Home Built 79 March 7th 05 01:42 PM
Looking for a fuselage Jay Honeck Aviation Marketplace 72 March 7th 05 01:42 PM
