RV-7a baggage area
Old December 5th 03, 05:51 PM
RR Urban
Hello All,
I am strongly considering the RV-7a and am interested in knowing the
dimensions of the baggage area behind the seats.
Thanks
David
"EUTNET" wrote:
Baggage 100 lbs
ARRRGH.
Go directly to jail.
Do NOT pass GO.
Do NOT collect $200.
Monopoly BOb --
Old December 7th 03, 02:07 AM
Dave S
And hence we have ANOTHER person who cannot tell the difference between
MASS and VOLUME.
I feel your frustration.
And.. whats sad is.. the person who said 100 pounds probably thought
they were being helpful by pointing out something "obvious"
Dave
RR Urban wrote:
Hello All,
Thanks
David
"EUTNET" wrote:
Baggage 100 lbs
ARRRGH.
Do NOT pass GO.
Monopoly BOb --
Old December 8th 03, 03:59 PM
Russell Kent
MASS and VOLUME.
Dave
Those that point out the mistakes of others would do well to mind their
own. Pounds (lbs.) are a measure of weight, not mass (which in the English
system would be slugs).
Van's own web page shows the baggage area to be "12+ cu. ft." If you need
a more precise number, I would suggest contacting Van's Aircraft directly.
http://www.vansaircraft.com/public/rv-7spe.htm
Russell Kent
Old December 8th 03, 08:24 PM
Gene Nygaard
On Mon, 08 Dec 2003 09:59:10 -0600, Russell Kent
MASS and VOLUME.
Dave
own.
Heed your own advice, fool.
Where'd you get that idea?
Gene Nygaard
http://ourworld.compuserve.com/homepages/Gene_Nygaard/
Gentlemen of the jury, Chicolini here may look like an idiot,
and sound like an idiot, but don't let that fool you: He
really is an idiot.
Groucho Marx
Old December 8th 03, 09:02 PM
Russell Kent
Russell Kent wrote:
Those that point out the mistakes of others would do well to mind their own.
Gene Nygaard responded:
On entirely too many occasions I am indeed a fool, but I don't see where
devolving to name calling improves the conversation. Besides gently (IMHO)
chastising the intervening poster's rant, I still provided a useful answer to
the original poster's question (12+ cu. ft.) and a reference to the source.
Russell Kent continued:
Pounds (lbs.) are a measure of weight, not mass (which in the English system
would be slugs).
Uh, 2 years of high school physics (a jillion years ago). Perhaps a few web
references will help clear the cobwebs:
http://scienceworld.wolfram.com/physics/Slug.html
http://www.physics.ucla.edu/k-6connection/Mass,w,d.htm
Russell Kent
Old December 8th 03, 09:19 PM
Russell Kent
OK, I know it's bad form to follow-up one's own posting. So sue me. :-)
Gene,
I see from your signature that this "weight vs. mass" thing is a personal windmill
for you. Fine. And I see that slug isn't used anymore (pound-force is the term
now). And for non-technical conversations, pound is a unit of mass.
Here's a question though: is this forum a technical or non-technical conversation?
And look at the sequence of postings: EUTNET wrote that the baggage area dimension
was 100 lbs, obviously meaning *weight*, and Dave S. complained that EUTNET
"cannot tell the difference between MASS and VOLUME." [emphasis Dave's] So I
believe Dave should have instead written "WEIGHT and VOLUME."
Now I suspect that Dave S. was merely careless and really does understand the
difference between mass and weight, and I was trying to gently pass along the
advice that newsgroup corrections are invariably inspected for even the slightest
error (see this thread!). I welcome you (Gene) jumping in at that point to
correct the whole weight vs. mass, slugs, pound-force hullabalu, but I wish you'd
do it with a bit less hostility. Someone may well have ****ed in your cornflakes,
but I assure you it wasn't me. :-)
Russell Kent
would be slugs).
Russell Kent
Old December 8th 03, 09:26 PM
Gene Nygaard
On Mon, 08 Dec 2003 15:02:03 -0600, Russell Kent
I see that even that wasn't enough to get your attention, Chicolini.
How big a bat do I need to hit you over the head with to get your
attention?
Yes, you got that right. Too bad nobody will pat you on the back for
it, because you obscured it with irrelevant nonsense, and even worse,
an incorrect claim of error on someone else's part.
would be slugs).
If you found those references, you also found many that got it right.
Slugs are units of mass. That's not what I'm calling you on.
But that little-used 20th century invention, which didn't even appear
in physics textbooks before 1940, are by no stretch of the imagination
_the_ units of mass in "the English system."
Pounds force also exist, but that's also beside the point.
Back up your claim that pounds are not units of mass. That's where
you falsely claimed that Dave S. was making an error.
Gene Nygaard
"It's not the things you don't know
what gets you into trouble.
"It's the things you do know
that just ain't so."
Will Rogers
Old December 8th 03, 09:43 PM
Russell Kent
OK, you got me there. Haven't a clue who Chicolini is. Should I be insulted? Do
you now feel better having insulted me?
attention?
Clear, intelligent statements usually work.
it,
(I don't care)
Irrelevant? Wasn't to me. Nonsense? Um, nope.
and even worse, an incorrect claim of error on someone else's part.
Perhaps.
I just grabbed a few that looked to get to the point quickly.
It wasn't clear in your earlier hostile response.
I'm sorry, you're correct. I didn't mean to imply that they are the only unit of
mass. I was taught (perhaps incorrectly) that the unambiguous term for weight
(scientific meaning) in the English system was "slugs". Apparently it's also
"pounds force" now (it may have been them, too, and I've just forgotten it).
sarcasm Whew. Glad we're past that. /sarcasm
Back up your claim that pounds are not units of mass. That's where you falsely
Actually, I intended only to claim that Dave S. incorrectly stated mass when he
should have stated weight. From my perspective, the respondent about whom Dave S.
was complaining clearly intended "lbs" as a unit of weight.
The reference to the slug as the English mass unit was only intended as an offhand
remark. Pounds are units of mass in casual (non-technical) conversations, and
probably shorthand for "pounds force" in technical conversations.
For the record, I don't claim that slugs are the only unit of mass in the English
system, and I'm sorry to have inadvertantly made that implication.
Russell Kent
Stearman for rent in Bay Area John Harper Aerobatics 7 April 5th 04 07:20 AM
Where can one get aerobatic training in the seattle area? SeattleFlyer Aerobatics 1 January 22nd 04 02:56 AM
