Overspeeding on winch launches
Old November 6th 17, 04:46 PM posted to rec.aviation.soaring
Scott Williams
Default Overspeeding on winch launches
On Monday, November 6, 2017 at 6:48:16 AM UTC-6, Dan Schmitz wrote:
I'm wondering what the consequences of overspeeding on winch launches are? I understand that it places stress on the airframe, but to what extent?
I find it near impossible to control the airspeed on the top third of a launch and have found myself over speeding the placarded max. speed by 5 - 10 knots a few times despite signalling to the winch driver.
Should I be taking the approach of releasing at 2/3 of typical launch height (e.g. 700 - 800 foot) if my airspeed isn't under control at this point?
Thanks in advance
When our club was winching fairly often, I was one of the winch drivers (with only a 3-4 hundred runs though). As the glider begins to reach the last third of the launch, the power must back off, sometimes to barely above idle. this is especially true if launching into a good brisk headwind.
Old November 6th 17, 05:11 PM posted to rec.aviation.soaring
Q: "I understand that it places stress on the airframe, but to what extent"
A: Up to the breaking strength of the weak link. Max ground launch speed is there to protect the weak link not the glider.
Old November 6th 17, 05:34 PM posted to rec.aviation.soaring
Tony[_5_]
That statement is not true when ground launching gliders certified under the old Glider Criteria Handbook in the USA. In that case the ground launch limit is a structural limit!
Old November 6th 17, 07:26 PM posted to rec.aviation.soaring
Tango Whisky
Well, you've got that wrong.
Tow release operations/launches vs launches/starts Jim Meade Soaring 1 February 9th 14 07:00 AM
Best winch metrics - what is the best winch operationally? Bruce Soaring 19 July 19th 09 11:45 AM
Do your straps up tightly for winch launches! Derek Copeland Soaring 22 October 23rd 06 09:34 AM
11 years between winch launches Mal Soaring 0 June 1st 06 01:00 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
