Overspeeding on winch launches
Old November 7th 17, 06:15 PM posted to rec.aviation.soaring
David Salmon[_3_]
Default Overspeeding on winch launches
At 17:28 06 November 2017, George Haeh wrote:
https://members.gliding.co.uk/bga-sa...safe-winching/
The BGA has published a an excellent winch launching resource.
Well worth memorizing at the beginning of every season.
The winch driver should be reducing power at the top of the launch as thi
is
where overspeed becomes critical.
Do remember to have a correct weak link.
I managed to break one just as I was releasing. Gusts and transmissio
surging
can add loads. That is what the weak link protects against. Th
manufacturer
airspeed limit gives some margin for gusts; so yes, on a calm day a small
airspeed exceedence might not break the weak link. But don't make it
habit.
We qualify in a 2-seater, but a single seater handles differently. Th
winch
generally has to run at the max for a 2-seater, but has excess power for
single
seater.
Tension can go up or down a few hundred pounds in very few seconds becaus
of gusts.
You can always invest in a Launch Assistant from Skylaunch. An ASI
transmitter in the glider, and a receiver/readout in the winch. Not that
expensive, and doesn't have to be a Skylaunch winch.
Dave
Old November 7th 17, 08:56 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Dave
So I see. That answers all my questions about size/weight/how it is
installed in the glider. Thanks.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old November 9th 17, 09:54 AM posted to rec.aviation.soaring
David Salmon[_3_]
that
Dave
org |
It is a small lightweight plastic box, from memory around 75x25x10. Needs
tee-ing in to the pitot and static lines, and also needs a 12v supply. So
light, it could be velcro'd under the panel, or tie wrapped. It detects the
start of the launch, at around 25kts, then transmits the airspeed to the
receiving unit in the winch, which has an analogue airspeed readout, then
after the launch, switches itself off. Check out the Skylaunch web site.
Dave
Old November 10th 17, 06:43 AM posted to rec.aviation.soaring
Peter Whitehead
I am going to purchase the kit for our expedition winch and auto-tow outfit, and one for my glider. A small price for higher and safer launches, compared to what we spend on 'gizmos'. I have no connection with Skylaunch though they have always provided great service and everything I have needed in terms of launching accessories.
The 'wheel has been invented'. We don't need to anguish over the question - "should I pull off before my wings are pulled off?"!
Old November 10th 17, 11:11 AM posted to rec.aviation.soaring
To me this looks like a great idea if almost every winch has it, but
otherwise a slight worry that it may affect my proficiency if my home
winch is equipped with it but winches at clubs I visit don't have it.
org |
Tow release operations/launches vs launches/starts Jim Meade Soaring 1 February 9th 14 07:00 AM
Best winch metrics - what is the best winch operationally? Bruce Soaring 19 July 19th 09 11:45 AM
Do your straps up tightly for winch launches! Derek Copeland Soaring 22 October 23rd 06 09:34 AM
11 years between winch launches Mal Soaring 0 June 1st 06 01:00 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
