Electric Towplane sets a new climb record
Old January 14th 18, 10:33 AM posted to rec.aviation.soaring
Dave Nadler
Default Electric Towplane sets a new climb record
On Sunday, January 14, 2018 at 8:32:19 AM UTC+13, Tony wrote:
My experience in the Electro in Uvalde and Kansas is that motor temp
becomes an issue well before battery and controller temp.
Depends on the machine. Antares has better motor cooling,
but batteries start to get hot and require early shutdown
at Uvalde for example (I typically shut down 800-1000 ft).
Perhaps cooling for enclosed FES motor isn't as good?
See ya, Dave
Old January 14th 18, 01:30 PM posted to rec.aviation.soaring
See ya, Dave
Pylon mounted motor will obviously cool much more easily than enclosed motor cooled through a small hole. Each concept has it's trade offs.
UH
Old January 24th 18, 05:17 PM posted to rec.aviation.soaring
Soartech
UH
Pylon mounting is the way to go. The FES self-launchers are VERY tricky to launch on a grass field because the prop tip is just a few inches off the ground. I have watched a friend blow up his prop on a grass field with just small bumps in it.
I like the new Polish GP series. The electric motor extends and retracts in just 4 seconds! Too bad there is a 2 year wait. The batteries are adequete now and will get better. There is a huge worldwide effort now to improve them.
360 HP Electric Extra Sets Climb Record Larry Dighera Piloting 0 December 9th 16 10:08 PM
Siemens' 110 lb world-record electric aircraft motor produce 348 hp at 2,500 RPM Larry Dighera Piloting 29 December 2nd 15 08:29 PM
electric speed record (141kts) with a cricri Philippe[_4_] Home Built 0 September 13th 10 07:31 AM
