ASH-25J Crash in Aus
Old January 22nd 18, 08:42 PM posted to rec.aviation.soaring
Mike the Strike
Default ASH-25J Crash in Aus
"It was on fire when it crashed..."
Mike
Old January 24th 18, 01:08 AM posted to rec.aviation.soaring
Dave Nadler
"GO" was equipped with a video monitor showing the engine area,
and IIRC (its been a few years) a fire-suppression system.
Paul was concerned and careful about the possible mishaps.
Sadly we'll probably never learn what happened.
Old January 29th 18, 06:36 PM posted to rec.aviation.soaring
Ramy[_2_]
Tragic accident. Since is was near an airfield chances are there were witnesses. It is important to know if the fire was the cause or the result of the accident. Is there more information available? I am sure many folks with jet sustainers would want to know more.
Ramy
Old January 30th 18, 01:05 AM posted to rec.aviation.soaring
The fire was before the crash, seen to be on fire on downwind.
Tom
Old January 31st 18, 11:33 AM posted to rec.aviation.soaring
Justin Couch
Tom
Confirmed.
This was the second engine bay fire in this particular glider. The reason it has the Jets fitted was because the previous motor caught fire and did a lot of damage. Rather than putting in a new engine, an experimental certificate was obtained and the dual Jet system installed. There's another ASH25M here in Oz that has also suffered an engine bay fire, coincidental or sign of a greater fault? We won't know for at least 12 months. The ATSB (aussie equivalent of NTSB) has taken control of the investigation. GFA is just a passenger now and waiting for the outcomes.
Old January 31st 18, 11:51 AM posted to rec.aviation.soaring
Justin, the previous engine in this glider had not run for probably 20 years, you sure this glider had a previous fire? I do know of two other ASH25 with fires, but ASH25Ms, not ASH25e. As you said, the ATSB are involved so a report eventually.
Tom
Old January 31st 18, 12:43 PM posted to rec.aviation.soaring
Justin Couch
Tom
I'll continue with you privately Tom, but note that the official designation of this glider is an M
http://m.regosearch.com/aircraft/au/GOA
Old January 31st 18, 03:17 PM posted to rec.aviation.soaring
Dave Nadler
That's not what Paul told me. The original motor in "GO" was an early
factory attempt at a sustainer, famous as as "less than optimum".
Another owner of this particular design told me he sold the engine/prop
immediately as it was the best possible way to dispose of it ;-)
Anyway, the compact jets permitted Paul to retrofit the jets without
making much change to structure (mostly using existing cutout etc).
...There's another ASH25M here in Oz that has also suffered an engine
Absolutely coincidental. This engine bay fire was caused by use of
non fire-proof material in a high-temperature area; subsequently
rectified by the manufacturer (as usual without admitting any fault,
nor admitting there had in fact been other instances).
This time the pilot (a good friend of mine) was incredibly lucky.
During take-off, some-one in the tower noticed the fire and called
him on the radio. He aborted take-off, and again fortunately someone
at the airport had a fire-extinguisher handy and got to the plane
shortly after it stopped rolling, so the fire was extinguished promptly.
IIRC it took more than a year to get everything back to working order...
Hope that helps clarify,
Best Regards, Dave
Old January 31st 18, 05:44 PM posted to rec.aviation.soaring
JS[_5_]
Best Regards, Dave
A fuel hose was the "material" in the 25M Dave mentions. It is a possibility in any internal combustion sustainer or SLSP with non-fireproof fuel lines, and that list is long. The 25M (one I have many hours in, before and after) fire on the runway at Keepit inspired me to buy a Safecraft fire extinguisher system, and have it installed in the 26E by someone knowledgeable both about gliders and putting out fires, now also the Schleicher rep in USA.
The 25 at Keepit now has a Safecraft system. Believe that Paul's converted 25E and others in Australia had extinguishers installed after I sent info on the 26E install. Seem to remember Safecraft shipping 5 systems to Australia.
At the time of the fire, the pilot of the 25M had an extinguisher in the car, ran and got it. The glider was so badly damaged that it had to be shipped back to Poppenhausen.
From the fire on the runway at Keepit I gathered there are three ways to deal with a fire.
Best: put it out right away.
Third best: find an extinguisher and then put it out.
Second best: get out and let it burn up.
The second best is an option on the ground or at altitude, but if there's a fire on downwind you're not in a great position to get out.
Perhaps Paul was stuck in that scenario. Maybe the fire had spread outside the engine compartment before pulling the handle on the extinguisher.
Wish we could ask.
Old February 1st 18, 08:39 AM posted to rec.aviation.soaring
Justin Couch
If you're talking about Dion's glider (DWA), it is still not in the air - onboard extinguisher system still not refitted as the bottle is out of certification and nobody wants to touch it (the aftermarket system mentioned up thread). I own his hangar now for almost 12 months and he was having problems before then with it.
SAS crash Peter DK Aviation Photos 5 September 11th 07 09:54 PM
vampire or venom crash pic - wx904 crash.jpg (1/1) [email protected] Aviation Photos 4 January 1st 07 07:30 PM
vampire or venom crash pic - wx904 crash.jpg (0/1) [email protected] Aviation Photos 0 December 30th 06 05:57 PM
Another GA crash in CA John Doe Piloting 29 March 20th 06 02:00 PM
MiG-29 crash on take off Iwan Bogels Military Aviation 19 September 15th 04 11:12 AM
