SkySight Soaring Weather Forecasting
Old March 22nd 18, 10:49 AM posted to rec.aviation.soaring
Default SkySight Soaring Weather Forecasting
On Thursday, March 22, 2018 at 10:21:01 AM UTC+9:30, wrote:
On Thursday, 22 March 2018 13:50:09 UTC+13, wrote:
On Friday, 16 February 2018 03:18:30 UTC+13, krasw wrote:
torstai 15. helmikuuta 2018 14.01.12 UTC+2 kirjoitti:
We are actually experimenting with ECMWF as an initialisation source. If it provides measurable improvement we will utilise it for regions where it does so.
Wow, I thought ECMWF boundaries would cost arm and leg to use commercially. I bet it provides measurable improvement, it is the best model currently available and on different level than GFS. Now if someone would run ensemble of RASP using ECMWF ENS members as boundaries, we would get usable thermal forecasts for next week instead of 2 days...
We run the WRF model with EC data. It is noticeably better - there are many more levels and the horizontal resolution we get is at 0.1 degrees vs the 0.25 for the GFS/GDAS. In addition, the EC analyses and forecasts are generally a lot better.
PS. It isn't cheap.
Hi,
I didn't see this thread alive again earlier, but as Paul/Jim deduced the forecast completed on the next run.
As to ECMWF, we are still testing. It's not so clear cut that it performs better for short term soaring forecasts due to their output intervals and timing. Contact me offlist if you want to know more.
Cheers,
Matthew
Weather forecasting experts at SSA Convention SF Soaring 9 February 13th 16 11:59 PM
weather-forecasting course danlj Soaring 0 March 19th 07 10:05 PM
FA Weather Study manual forecasting aviation 1942 AlisEvans Piloting 0 March 6th 07 11:50 PM
Aviation Weather Forecasting soaring pilots gliding FA JaneyP Soaring 0 January 24th 07 11:01 PM
Weather Question: forecasting clouds Jonathan Piloting 11 November 19th 04 08:34 PM
