#51
You are confusing Lipo with with li ion, the modellers problems were with lithium polymer batteries, not the type we are discussing.
#52
On Thursday, April 5, 2018 at 10:20:48 AM UTC-7, Richard Pfiffner wrote:
On Thursday, April 5, 2018 at 8:04:40 AM UTC-7, Tango Eight wrote: On Thursday, April 5, 2018 at 10:52:17 AM UTC-4, Richard Pfiffner wrote: On Wednesday, April 4, 2018 at 10:16:45 PM UTC-7, kinsell wrote: On 04/04/2018 04:04 PM, Richard Pfiffner wrote: On Wednesday, April 4, 2018 at 2:31:07 PM UTC-7, kinsell wrote: Wow. Didn't these batteries have a battery management system to prevent damage? On 04/04/2018 03:22 PM, Richard Pfiffner wrote: John, My experiences with LiFePO4 I have never heard of a LiFePO4 battery catching fire. I have had some customers connect reverse polarity. It burnt up the internal positive wire but the battery did not burn. I also just shorted a LiFePO4 12V10Ah turned it upside down and placed on a metal plate. It got hot and distorted the case near the contacts for the cells. It did not burn and was cool when I looked at it 1/2 hour later. I had one supplier that gave me 24 Volt chargers by mistake. I charged one battery overnight and it got very large but did not catch fire.. Richard www.craggyaero.com I have found that BMS will not save a short. Richard www.craggyaero.com A good short should bring the terminal voltage below 10 volts instantly, strange the BMS didn't kick in before damage occured. Also a bood BMS ought to prevent overcharging , which clearly didn't happen with the 24 volt chargers. If I had a battery swell in my ASH-26E, it would cause some significant damage. The overcharging was a Stark Battery. I will try the short on the famously expensive K2 battery today. Standby for results. Richard www.craggyaero.com Need video :-). T8 Video shows nothing battery gets hot and cuts out at I suspect about 10V. Richard www.craggyaero.com Richard, try dropping a similar sized SLA on a metal plate. |
#53
On Thursday, April 5, 2018 at 8:14:21 PM UTC-7, jfitch wrote:
On Thursday, April 5, 2018 at 10:20:48 AM UTC-7, Richard Pfiffner wrote: On Thursday, April 5, 2018 at 8:04:40 AM UTC-7, Tango Eight wrote: On Thursday, April 5, 2018 at 10:52:17 AM UTC-4, Richard Pfiffner wrote: On Wednesday, April 4, 2018 at 10:16:45 PM UTC-7, kinsell wrote: On 04/04/2018 04:04 PM, Richard Pfiffner wrote: On Wednesday, April 4, 2018 at 2:31:07 PM UTC-7, kinsell wrote: Wow. Didn't these batteries have a battery management system to prevent damage? On 04/04/2018 03:22 PM, Richard Pfiffner wrote: John, My experiences with LiFePO4 I have never heard of a LiFePO4 battery catching fire. I have had some customers connect reverse polarity. It burnt up the internal positive wire but the battery did not burn. I also just shorted a LiFePO4 12V10Ah turned it upside down and placed on a metal plate. It got hot and distorted the case near the contacts for the cells. It did not burn and was cool when I looked at it 1/2 hour later. I had one supplier that gave me 24 Volt chargers by mistake. I charged one battery overnight and it got very large but did not catch fire. Richard www.craggyaero.com I have found that BMS will not save a short. Richard www.craggyaero.com A good short should bring the terminal voltage below 10 volts instantly, strange the BMS didn't kick in before damage occured. Also a bood BMS ought to prevent overcharging , which clearly didn't happen with the 24 volt chargers. If I had a battery swell in my ASH-26E, it would cause some significant damage. The overcharging was a Stark Battery. I will try the short on the famously expensive K2 battery today. Standby for results. Richard www.craggyaero.com Need video :-). T8 Video shows nothing battery gets hot and cuts out at I suspect about 10V. Richard www.craggyaero.com Richard, try dropping a similar sized SLA on a metal plate. I suspect a fire or at least a lot hotter. Richard. |
LiFePO4 batteries | JS | Soaring | 26 | October 15th 12 02:51 PM |
Batteries Included | Mitchell Holman | Aviation Photos | 0 | September 21st 08 12:33 AM |
AGM Batteries | Dave Anderer | Owning | 13 | March 29th 08 07:38 PM |
2-Batteries | [email protected] | Soaring | 69 | January 4th 07 04:09 AM |
160 new batteries | Mal | Soaring | 0 | October 27th 06 11:36 AM |
