Libelle 201 Canopy
Old July 17th 18, 02:06 AM posted to rec.aviation.soaring
Default Libelle 201 Canopy
Thanks Jim and Steve. I'm located in California. That Blue tint canopy from Germany looks great I'll send an inquiry with google translate to segelflug for cost. I'm new to sailplanes and don't know Rex, forgive my ignorance. Could you explain in more detail?
Old July 17th 18, 02:47 AM posted to rec.aviation.soaring
JS[_5_]
Rex owns Williams Soaring Center, in Williams California.
Timing was right for us, so the Libelle canopy was shipped together with a canopy for an ASH25.
You never know when there'll be a shipment with room for a canopy...
(aka consolidation)
Old July 17th 18, 03:22 AM posted to rec.aviation.soaring
Thanks I saw a recommendation that Williams may have a used canopy that I could get. I'll give Rex a call.
Old July 17th 18, 07:39 PM posted to rec.aviation.soaring
Graham Drinkell[_2_]
canopy
fr=
segelf=
ignoranc=
with a
(aka consolidation)
Hi, I know of a local company in Colchester, that can produce a tinted
canopy for a Libelle for around £400. The best tint option is brownish-
makes spotting thermals far easier than a blue tint?
Old July 29th 18, 03:06 AM posted to rec.aviation.soaring
Less than $500.00 USD shipping to California probably another 80-100. That's affordable for me. Would you give me the name of that company that produces those transparencies. I'm still planning to look around here a while and called Rex today. Considering building a plug and giving a go at forming one. The Libelle is probably one of the smallest sailplane canopies. Sourced the acrylic for around $120 for an appropriate sized sheet can obtain in clear, smoke tint, bronze, blue, light blue, clear. Definitely a task to make one but not too hard.
Old July 29th 18, 05:37 AM posted to rec.aviation.soaring
Charlie Quebec
A local here in Aus tried starting out making a Libelle canopy from a plug. It took 7 years to get it right, as the pointy rear top caused lots of problems.
He now knocks out mould then plug in 3 months. Making a plug that stays stable at 150C is not easy.
He uses no vacuum, and the plug has to take 2 tons of pressure to withstand the force of the giant press built into the oven.
Good luck, you will need it.
Old July 29th 18, 02:49 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
A worthwhile read on how to make your own moulded canopy.
http://ssa.org/Archive/ViewIssue.asp...onth=6&page=31
June 1975 SOARING, starts on page 31. If you search the SOARING archive for "Bob Walters" you will find some more articles by him and about his Duster. A beautiful plane. Later, he designed and built the Dragonfly. A two seat, side by side, tandem wing (similar configuration to the Rutan Quicke) airplane. He stopped overnight at Sunflower Gliderport on his way to its Oshkosh debut!
Not saying don't try it. Just saying you should be aware that it may not be as easy as it appears!
Steve Leonard
Old July 31st 18, 09:56 PM posted to rec.aviation.soaring
Thanks Steve I don't have an SSA membership as of yet when I do I'll plan on reading the article that Mr. Walters wrote. Im actually making payments on a Dragonfly. To Gram could you provide the contact info for the Libelle canopy you mentioned. There's a good chance I would pick up a transparency from them.
Libelle 201 canopy [email protected] Soaring 0 July 4th 16 02:03 PM
Canopy Ejection and Canopy Lanyard Casey[_2_] Soaring 6 April 12th 16 05:09 PM
Std Libelle Low profile canopy blank [email protected] Soaring 0 November 7th 15 09:35 PM
Libelle Canopy Tom Watson Soaring 4 February 27th 12 11:59 PM
Wanted Libelle 201b Canopy Fish Soaring 2 June 1st 06 07:10 PM
