Brake caliper flange
Old July 3rd 03, 03:09 PM
Rich S.
"Stealth Pilot" wrote in message
Chris the W8 tailwind I fly has 5.00x5 cleveland brakes and hubs.
the flange plate isnt welded to the wittman leg on mine.
there is a piece of tube(about an inch or so long) which is a snug
sliding fit over the inner end of the axle. this has a 4130 "washer"
over it welded to make an annular flange. this tube collar is located
on the axle by a single AN3 bolt.
(btw if my memory is faulty the bolt is definitely no bigger than AN4)
the bolt through the axle intersects the collar twice (once on each
side) so it is in double shear.
the cleveland brake locating plate bolts to the "washer" with 4 AN3
bolts.
has been in use for 500 hours over 18 years.
Then it would seem that you have been carrying 4 unneeded bolts, nuts and
maybe washers around Oz for lo these many years. )
Rich "Why have four when two will do?" S.
Old July 3rd 03, 10:01 PM
Ernest Christley
bolts.
One thing to keep in mind is that the bolt through the axle, unlike the
ones on the calipers, will get nearly zero twisting moment.
----Because I can----
http://www.ernest.isa-geek.org/
Old July 3rd 03, 11:13 PM
Rich S.
"Ernest Christley" wrote in message
. com...
If properly installed, the brake disk and the mounting flange will be almost
exactly inline. Any twisting moment will be negligible.
See http://temp.corvetteforum.net/c4/elw.../cleveland.jpg
Rich S.
Old July 7th 03, 05:46 AM
Ernest Christley
. com...
Rich S.
But if all the corners aren't bolted securely, they will not be inline
very long.
Old July 7th 03, 04:19 PM
Rich S.
. com...
very long.
Then use four smaller bolts with the equivalent total shear strength of the
single thru-axle bolt.
Aircraft *must* be light to perform well. One does not build a light
aircraft by ignoring details such as this. A friend of mine built an RV-4.
Before final assembly I remember him going over the airframe and examining
each bolt for proper length. All unnecessary washers were removed and bolts
replaced if they were now too long. Maybe he saved an ounce or two. That's
an ounce or two he doesn't have to cart around for the next few years. At
U.S. Postal rates, that adds up! ;o)
Rich S.
P.S. Yes, I realize that misaligned holes can throw all of the shear force
on one bolt. Drill the *&^% holes right and you won't have that problem.
Brake line design question Charlie Smith Home Built 0 July 2nd 03 12:31 PM
