On Sunday, May 5, 2019 at 6:26:52 PM UTC-7, Nelson Howe wrote:
Not knowing any better, I used Aeroshell 4 when I bled and topped up the hydraulic brake system in my Discus 2b. Initially it got the sponginess out of the brake. After working on it some more about a week later, I found it impossible to bleed the system further ( I thought I might still have a little air in the line) as the piston was very very slow to return after squeezing the handle. I also noticed that the rubber gasket membrane thing in the lid was deformed. After reading up on things a bit, I realize this (Tost) system calls for Dot 3-5 fluid and not the red stuff. So how much damage have I done? What do I need to replace? I believe the rubber components have to be a different type of rubber for each hydraulic fluid. So you probably need to replace all the rubber components. |
Adding ASW-24 Brake Fluid | [email protected] | Soaring | 6 | October 30th 16 06:50 AM |
Replacement fluid for corba hydraulic jack??? | [email protected] | Soaring | 16 | April 20th 16 12:39 PM |
5606 Aviation Brake Fluid | John Sullivan | Soaring | 8 | March 30th 11 05:51 AM |
Pitts brake fluid | Al MacDonald | Aerobatics | 2 | April 25th 05 03:43 AM |
BRAKE FLUID | Ventus B | Soaring | 9 | October 17th 04 07:25 PM |
