When to apply gap seal tape
Old May 8th 19, 03:02 AM posted to rec.aviation.soaring
soaringjac
Default When to apply gap seal tape
On Tuesday, May 7, 2019 at 4:18:50 PM UTC-7, Bob Youngblood wrote:
On Tuesday, May 7, 2019 at 4:56:57 PM UTC-4, soaringjac wrote:
I am going to be using 3M perfect it followed by WX Block/Seal. Just wondering when in the process i should apply the new gap seals? I think i read that the seals/tape does not stick too well to freshly WX block/sealed surfaces. Should i put them on now and then mask them off, and then do the whole 3M/WX block seal process?
You will get many opinions here, do what works for you! As for myself I do my waxing and clean the entire tape edge with a good cleaner such as acetone, or other high evaporating cleaner. Then apply the tape, it works for me.
Thanks Bob!
Solvent for Gap-Seal tape prep AS Soaring 15 August 15th 17 03:54 PM
LS4 aileron gap seal and mylar seal width Eric Foertsch Soaring 8 May 18th 17 07:50 PM
Does part 91 apply outside the USA? Barry Piloting 1 February 5th 08 09:58 AM
Does part 91 apply outside the USA? Barry Piloting 1 February 5th 08 01:48 AM
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 04:35 PM
