Updating FLARM F4/F5 without SD card slot
Old May 22nd 19, 06:12 PM posted to rec.aviation.soaring
Default Updating FLARM F4/F5 without SD card slot
You've had some really excellent explanations of the procedure.
I just wish to draw your attention to the settings.
The Flarmtool software lets you set the Flarm's parameters and communication settings.
I usually find that my preferred settings are overwritten by default every time I update the firmware.
My preferences a
.. max permissible H range
.. max permissible V range
.. competition mode (less alarms)
.. 19200 com speed.
.. Position+traffic info active on external port (GPS+Flarm sentences) (if not, you won't be able to connect to external instruments and viewers)
Definitely worth checking. After the update has been completed, disconnect and then reconnect your Flarm, use Flarmtool, explore and adjust the settings. This will save you the time to troubleshoot all your connections and then redoing the Flarmtool procedure.
Aldo Cernezzi
www.voloavela.it
Updating to Flarm 6.42 seems to fail? jfitch Soaring 13 February 27th 18 06:36 AM
AL-KO Cobra Trailer Coupler Keyhole Slot? OHM Ω http://aviation.derosaweb.net Soaring 8 October 23rd 17 10:59 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Summer (Dec-April 09) Tow Pilot / Instructor(s) wanted for NZ -Repost as one filled slot has become available again [email protected] Soaring 0 September 4th 08 06:57 AM
!!! WARNING -- AOPA credit card holders. The credit card company is trying to change the rules in mid-game. Read the statement sent to you by MBNA. Chuck Owning 22 May 23rd 05 12:37 AM
