LXNAV S100 calibration and firmware question
Old May 23rd 19, 08:59 PM posted to rec.aviation.soaring
vtcyclist
Default LXNAV S100 calibration and firmware question
I have an S100. I want to calibrate it and have removed it from the glider.. We’ve put it in the calibration chamber, but are not having any luck getting it to record a flight without the gps recognizing movement. Ideas?
Second. I’ve updated firmware before without issues. This time, the file is on the MicroSD, inserted into the slot, the S100 recognizes the update file and asks for “Update?”. I select with lower knob, and press/click to update. The screen goes dark and then stays off. When I restart the instrument, it asks if I want to update. Ideas?
Thanks.
Old May 23rd 19, 09:09 PM posted to rec.aviation.soaring
Ron Gleason
On Thursday, 23 May 2019 13:59:43 UTC-6, vtcyclist wrote:
I have an S100. I want to calibrate it and have removed it from the glider. We’ve put it in the calibration chamber, but are not having any luck getting it to record a flight without the gps recognizing movement. Ideas?
Thanks.
Send to Richard at Craggy Aero http://craggyaero.com/
Old May 23rd 19, 09:15 PM posted to rec.aviation.soaring
vtcyclist
Ron. Thanks for the suggestion. At the top of Craggy’s LXNAV page is the warning not to download LXNAV files with an Apple product. That solves the firmware problem.
Old May 23rd 19, 10:55 PM posted to rec.aviation.soaring
jp
Glad that worked for you. I've downloaded LXNAV files to my Apple MacBookPro many times and they always worked for me. Anyway, whatever works for you is what is important.
Old May 24th 19, 04:09 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Almost every time some one calls about a firmware problem with LXNAV & PowerFlarm it is because they tried to download with an Apple Computer or and Apple computer with a Windows emulator.
Richard
www.craggyaero.com
Old May 24th 19, 08:03 AM posted to rec.aviation.soaring
Darryl Ramm
Richard
www.craggyaero.com
And the new PowerFLARM 6.60 firmware fixes that mac compatibility issue, but the irony is folks are having trouble upgrading to that using a Mac :-)
For now with a Mac you can manually remove the unneeded hidden files that the Mac is putting on the USB stick, they are throwbacks to old Mac compatibility resource fork crap. Deleting the hidden files affects nothing, just makes the FLARM update work. Easiest way is to use the Terminal.app on the Mac to find and remove any ._filename.ext hidden files (e.g. ls ._* to see them). If needed find a kid who knows UNIX/linux to help you, take then for a glider ride in return.
Old May 24th 19, 01:19 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Richard
www.craggyaero.com
I am not as versed in electrons as most engineers on this site, so what I am saying is more visceral. I have been a Mac user since 1984, with just a few brief virus, trojan, and ransom filled forays into the PC world. When I got back into gliding after a 15 year hiatus, the instruments and software had developed to the Piont I now needed to access the data. Thought about using the Mac, but then for with little research I purchased a Levono 900 used for $400. Macs are expensive and I didn't want to expose it to the desires and diseases of the other side of the tracks
Old May 24th 19, 03:35 PM posted to rec.aviation.soaring
Dan Marotta
Is there an Apple/Mac simulator that runs on a PC?
Richard
www.craggyaero.com
Dan, 5J
Old May 24th 19, 03:51 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
On Macs with Sierra or later insert usb stick, show in finder.
CMND + SHIFT + Period this will show the hidden files.
Delete as required.
Old May 24th 19, 03:54 PM posted to rec.aviation.soaring
kinsell
Put a Linux like Ubuntu on your PC. Fast, stable, secure, and free.
Ron.* Thanks for the suggestion.* At the top of Craggy’s LXNAV
product.* That solves the firmware problem.
Glad that worked for you.* I've downloaded LXNAV files to my Apple
MacBookPro many times and they always worked for me.* Anyway,
Richard
www.craggyaero.com
using a Mac :-)
what I am saying is more visceral.* I have been a Mac user since 1984,
PC world.* When I got back into gliding after a 15 year hiatus, the
access the data.* Thought about using the Mac, but then for with
little research I purchased a Levono 900 used for $400.* Macs are
Air glide Vario family versus S100 LXNAV - Comments on Winds and Performance? WaltWX[_2_] Soaring 11 December 17th 18 10:01 AM
Anyone having trouble upgrading firmware in an LXNAV s80? Matt Herron Jr. Soaring 2 January 17th 18 03:56 AM
LX S100 Bryce Sammeter Soaring 2 November 1st 17 08:43 AM
LXNav S80 latest firmware ZP Soaring 0 November 20th 16 05:26 PM
LXNav S80 Vario Digital Input Wiring Question Gianni Isotope Soaring 1 July 14th 16 11:16 PM
Copyright 2004-2024 AviationBanter.
