Fuse for radio
Old July 15th 19, 04:07 PM posted to rec.aviation.soaring
krasw
Default Fuse for radio
On Sunday, 14 July 2019 21:40:14 UTC+3, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
On Saturday, July 13, 2019 at 11:24:31 AM UTC-5, soaringjac wrote:
Anyone know what fuse rating i would need for an old Edo-Aire RT-551 radio. Its marked inop now but i still want to replace the fuse in the panel for it
Between you, me, and the fence post, I prefer breakers rather than fuses. Breakers are easier to reset while in flight than replacing fuses.
Remember to use a minimum of 3A fuses/breakers or risk loosing precious volts. See page 86 of this presentation http://aviation.derosaweb.net/presentations/#wiring.
John OHM
Why would you ever need to reset breaker during flight? Breakers protect your wiring, if your wires shorted, are you sure you wan't to reset the situation during flight?
Old July 15th 19, 04:57 PM posted to rec.aviation.soaring
kinsell
John OHM
In many years of flying, never have blown a fuse or popped a breaker.
If your wiring is shorted or an instrument has a fault, take care of it
on the ground.
Personally I think a five amp blown fuse is the perfect companion for an
inop radio. Why waste your money on a breaker?
Cambridge 302 fuse [email protected] Soaring 6 December 18th 18 03:36 PM
ASW 27 Fuse ballast tank FS pat Soaring 0 July 22nd 12 05:56 PM
B40 fuse question Tuno Soaring 3 December 8th 08 07:43 PM
KR-2 fuse for sale Turbo Tiger Home Built 3 December 17th 05 06:27 PM
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
