Garmin Aera 660 vs ifly 720
Old August 6th 19, 01:40 AM posted to rec.aviation.soaring
Default Garmin Aera 660 vs ifly 720
So my Garmin 196 gave up the ghost and is not updatable anyway. So Im looking to replace it with one of the two above. One big question is (and I searched both manuals before asking this) do either of them give the current required glide ratio to a point? My 196 did and I had it on my custom field. It was extremely helpful for final glides. Both of the units Im looking at have VNAV functions but cant tell if the have what Im looking for in the size the come in. Any one have experiance with either of these? Thanks
Cliff Hilty ASW27 CH
Old August 6th 19, 09:11 PM posted to rec.aviation.soaring
2G
On Monday, August 5, 2019 at 5:40:11 PM UTC-7, wrote:
So my Garmin 196 gave up the ghost and is not updatable anyway. So Im looking to replace it with one of the two above. One big question is (and I searched both manuals before asking this) do either of them give the current required glide ratio to a point? My 196 did and I had it on my custom field.. It was extremely helpful for final glides. Both of the units Im looking at have VNAV functions but cant tell if the have what Im looking for in the size the come in. Any one have experiance with either of these? Thanks
The Aera 660 can display glide ratio in a user-defined data box. It also has a vertical nav (VNAV) feature that is similar to a glide computer. All of this is explained in its manual:
http://static.garmin.com/pumac/190-02017-20_e.pdf
I have seen the 660, and the display is quite bright in direct sunlight. A friend has one that he uses to display XM weather (needs the GDL-52 receiver).
Tom
Old August 6th 19, 11:04 PM posted to rec.aviation.soaring
I read that Tom, but it seems it only displays what you are getting for a glide ratio not what you need to a fixed point. I do like the look and ease of ops with the aera 660. I talked with tech support for both units and niether will do what the 196 did, but Ifly is working on that in a next gen software. I also like the ipad/ foreflight that now has the amoeba for reachable glide. Its just alittle big in my limited cockpit space. In the mean time I found a used 196 for a 100 bucks on ebay
Old August 6th 19, 11:25 PM posted to rec.aviation.soaring
2G
The VNAV feature is a glide to a waypoint.
Tom
Old August 6th 19, 11:42 PM posted to rec.aviation.soaring
True but it is given in fpm descent not glide ratio.
Old August 8th 19, 01:54 AM posted to rec.aviation.soaring
2G
So what? Can't you do a simple conversion?
Aera 510 problems Stinky Feet Instrument Flight Rules 0 May 28th 12 11:36 PM
XM Wx Garmin 430/430W with Garmin GDL-69? [email protected] Instrument Flight Rules 4 March 5th 07 03:52 AM
Garmin 496 loss of satellite reception--Garmin's answer Dan Luke Piloting 0 August 22nd 06 05:32 PM
Garmin 496!!! Mike Granby Piloting 25 July 24th 06 04:03 PM
This is why Garmin 296's street price has been dropping -> Garmin 396 [email protected] Instrument Flight Rules 7 July 11th 05 06:39 PM
