Ooooops...
Old August 16th 19, 07:11 PM posted to rec.aviation.soaring
Default Ooooops...
I am going to go mediate ohm...
My favorite definition of "Ohm's Law" is "The regulation that gives the valuable Airport Loony concession to the Hare Krishnas."
Old August 27th 19, 03:30 AM posted to rec.aviation.soaring
2G
Default Ooooops...
How can you guys disparage such a Joule of an airplane?
Old August 27th 19, 03:35 AM posted to rec.aviation.soaring
Darryl Ramm
Default Ooooops...
Watt is your problem?
Old August 27th 19, 03:41 AM posted to rec.aviation.soaring
Joel Flamenbaum[_2_]
Default Ooooops...
On Wednesday, August 14, 2019 at 2:22:01 PM UTC-7, Dave Nadler wrote:
https://www.reuters.com/article/us-n...KCN1V423N?il=0
Watt due you all mean with such negativity - try and bee more positive to charged events
Old August 27th 19, 10:49 AM posted to rec.aviation.soaring
kinsell
Default Ooooops...
Kirchoff sez watt goes up must come down. Not just a good idea, it's
The Law.
Old August 27th 19, 01:42 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
Default Ooooops...
A lot of reactance here. No resistance to commenting.
Old August 27th 19, 02:13 PM posted to rec.aviation.soaring
Default Ooooops...
Seems he hit the "ground" through no "fault" of his "ohm"...
  #28
Old August 27th 19, 02:39 PM posted to rec.aviation.soaring
Default Ooooops...
Resistance is futile. But inevitable.
  #29
Old August 27th 19, 03:13 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default Ooooops...Electrically
Would a salt water landing have had more potential for grounding the aircraft properly?
  #30
Old August 27th 19, 06:07 PM posted to rec.aviation.soaring
Tango Eight
On Tuesday, August 27, 2019 at 10:13:57 AM UTC-4, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
The very idea is revolting.
T8
