Phrase "landing runway" vs. "cleared to land"
Old January 18th 08, 08:01 PM posted to rec.aviation.piloting, rec.aviation.ifr
Robert M. Gary
Default Phrase "landing runway" vs. "cleared to land"
On Jan 17, 8:48*pm, wrote:
Approach lights are part of runway environment...
Then you are clearly wrong. The fact that you see the approach lights
certainly does not indiciate that you have any visibility. As I
mentioned before you can see the approach lights through the fog but
not be able to see the ground around the lights. So your statement
that seeing the environment demonstrates the visibility, if you
include the apporach lights, cannot be correct.
-robert, CFII
  #112
Old January 18th 08, 08:05 PM posted to rec.aviation.piloting, rec.aviation.ifr, rec.aviation.student
Robert M. Gary
On Jan 18, 5:26*am, " wrote:
On Jan 17, 9:15 pm, "Robert M. Gary" wrote:
I only teach in Monneys but I'm not sure why you would need to be
faster without flaps. Even if I used flaps I wouldn't change the speed
on the approach. Are you flying ILSs in a 172 at 50 knots such that
you need flaps?
Nope --100-90 KIAS in an A36, 90 KIAS in a 172. Approach flaps set in
the A36 and 10 degrees in 172.
I never noticed that as a problem in the A36. It was very stable at
100 knots without flaps. I never felt any tendancy for it to be
unstable.
But either way you have full flaps once you go visual so the landings
distance is the same in each technique.
While that may be the case in a particular Mooney or Cherokee or
Skyhawk, this method will not work in a faster (more slippery)
airplane.
What plane are you flying that is more slippery than a Mooney and that
does not slow when you deploy the flaps? Your A36 is a truck compared
to the slippery Mooney. I used to cook into San Jose Int'l in the A36
at 150 knots and drop the gear/flaps on short final. I could feel the
G's of the decelleration, so you can't tell me that your A36 won't
slow with flaps.
-Robert
  #113
Old January 18th 08, 10:05 PM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
Marco Leon wrote:
"Newps" wrote in message
That was wrong on the controllers part.
Wouldn't it be covered under here? Maybe he forgot to specifically say
"runway xx unsafe?"
No, this section has nothing to do with the topic at hand.
  #114
Old January 19th 08, 03:32 AM posted to rec.aviation.piloting, rec.aviation.ifr, rec.aviation.student
slow with flaps.
-Robert
The A56 drag coefficient is a bit more than a Lear and an F-104, so
it's pretty slippery.
In the Army we differentiated between doctrine and technique. Doctrine
everybody was to do, period. Technique was the method you employed to
achieve doctrine.
In this case "doctrine" is to arrive at the runway with as little
energy as possible, given the requirements of safety in the conditions
at hand.
If you can reconfigure the airplane on short final and reduce the
speed as appropriate to achieve this, then that's your technique.
But I think teaching this particular method as the only way for every
airplane is a mistake, as it will eventually lead to overly fast
landings when the student climbs aboard his/her faster airplane.
It just seems to me that a consistent, less drastic change in
configuration is the better technique.
Dan
  #115
Old January 19th 08, 03:37 AM posted to rec.aviation.piloting, rec.aviation.ifr, rec.aviation.student
Robert M. Gary
True, but its still a truck compared to a Mooney.
I think anyone who teaches either technique and claims its good for
all aircraft is probably full of crap. I wouldn't teach flying
approaches w/o flaps in a 767. When I'm giving training in the Mooney
or occasionally in the A36 people are looking for type specific
training. Showing them how its done in other aircraft (like a 767) is
not what they are looking for. In both those aircraft I find the no
flap approach best. Add to that that I live in a fog valley and
finding nothing but 0/0 at mins is not uncommon so shooting approaches
to mins in actual is not theory around here and neither are missed in
actual.
-Robert
  #116
Old January 19th 08, 03:46 AM posted to rec.aviation.piloting, rec.aviation.ifr, rec.aviation.student
actual.
-Robert
Well then there ya go...
Dan
  #117
Old January 19th 08, 04:59 AM posted to rec.aviation.piloting,rec.aviation.ifr
Jim Carter[_1_]
Some of them are never wrong...
Jeeze - I'd never have to take my wife to the comedy club if I could just
get her to read this group....
Jim Carter
Rogers, Arkansas
  #119
Old January 19th 08, 01:06 PM posted to rec.aviation.piloting,rec.aviation.ifr
On Fri, 18 Jan 2008 11:01:44 -0800 (PST), "Robert M. Gary"
-robert, CFII
I am not saying that at all.
Descent below the MDA, or continuation of the approach beyond DA,
requires 3 conditions:
1) Runway environment in sight
2) Normal rates of descent, etc...
3)Flight visibility as specified...
All 3 conditions must be met. Approach lights satisfy condition 1.
  #120
Old January 19th 08, 02:34 PM posted to rec.aviation.piloting, rec.aviation.ifr, rec.aviation.student
actual.
-Robert
So, you are able to:
Apply full flaps
Reduce speed from 90-100 K to 70 K
Continue descending to the touchdown point
Stabilize the approach at somewhere near 1.3-1.4 Vso
All beginning at 200' AGL?
Dan
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Piloting 168 February 5th 08 06:32 PM
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" Mike[_7_] Naval Aviation 50 November 30th 07 06:25 AM
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 08:48 AM
"Airplane Drivers" and "Self Centered Idiots" Skylune Piloting 28 October 16th 06 06:40 AM
