#161
In rec.aviation.piloting Mxsmanic wrote:
writes: And that tells you your course, not which direction the nose is pointed. For navigation, your ground track is more important. There is no GPS instrument available that will tell you which way your nose is pointed. As I've said, you just use two. There is are GPS instruments available that can be linked to tell you that. The only two places on Earth a magnetic compass doesn't work in an airplane are over the north and south magnetic poles. No. There are thousands of local magnetic anomalies that can make a compass useless. Not at airplane altitudes and speeds. If there are thousands, name just 30. Piston engines have magnetos which generate the spark plug firing voltage, and only the spark plug voltage. Last time I checked, sparks counted as electricity. Well, I can see electricity can be added to that ever growing list of things about which you know nothing. Magnetos generate pulses measured in the thousand of volts and microamps of current. Even if they were hooked to something else, which they aren't, the power generated would be useless for powering something like a GPS. My god, everytime you say something, more ignorance just roles out. -- Jim Pennino Remove .spam.sux to reply. |
#162
In rec.aviation.piloting Maxwell wrote:
"Mxsmanic" wrote in message ... writes: And that tells you your course, not which direction the nose is pointed. For navigation, your ground track is more important. There is no GPS instrument available that will tell you which way your nose is pointed. As I've said, you just use two. The only two places on Earth a magnetic compass doesn't work in an airplane are over the north and south magnetic poles. No. There are thousands of local magnetic anomalies that can make a compass useless. Piston engines have magnetos which generate the spark plug firing voltage, and only the spark plug voltage. Last time I checked, sparks counted as electricity. Then hook up a spark plug wire to your GPS. Better to his forehead; electroshock therapy sounds like it is called for in his case. -- Jim Pennino Remove .spam.sux to reply. |
#163
writes: They are still big, heavy, and expensive. Laser gyros are not big or heavy, although they are usually expensive. I'll skip the rest of your post, as there are more anomalies than I care to address. Or in other words, you don't know what the hell you are talking about and don't want to learn what an ignorant fool you are. -- Jim Pennino Remove .spam.sux to reply. |
#164
dgs writes: So, when he attempts to label people as stupid (even if only by implication), or treat others as if they're idiots, remember, he's actually proposing that he be treated as if he's stupid too. At least it's consistent. No. When I give honest assessments of something or someone, I expect others to do the same. Honest does not equal true. Honest just means that you aren't lying when you spout your ignorant, incorrect, nonsense; you really believe your own crap. -- Jim Pennino Remove .spam.sux to reply. |
#165
Maxwell writes: Odd..you are clearly the poster child for stupidity, but you don't see hostile. I'm neither stupid nor hostile. A smart person wouldn't keep spouting the same ignorant nonsense after they've been given references to eliminate the ignorance. -- Jim Pennino Remove .spam.sux to reply. |
#166
![]() "RomeoMike" wrote in message ... wrote: Astro navigation, but it's still an angle away from a standard vector. So different sciences are using the same word with different meanings. However, you're of course correct that for magnetic navigation, declination and variation are the same thing. http://www.ngdc.noaa.gov/seg/geomag/faqgeom.shtml Kev Thanks to you, farr1220, and Peter. I always wondered in the back of my mind how the term declination came to mean variation. Now I'm ready to navigate the outer space :-) Hmmmm. I see that what I have been calling declination is called inclination on the NOAA site, so I will correct as appropriate. In view of my recollections of ground school, I believe that it might be least confusing to continue using the term deviation for the instrument error as installed, variation for the difference between true and magnetic north, and inclination for the angle between the lines of force and the horizontal--leaving the term declination unused. Peter (Planning to think about this at leisure) |
#167
![]() "Peter Dohm" wrote in message .. . In view of my recollections of ground school, I believe that it might be least confusing to continue using the term deviation for the instrument error as installed, variation for the difference between true and magnetic north, and inclination for the angle between the lines of force and the horizontal--leaving the term declination unused. You could use declination for the difference between the magnetic variation a VOR is set to and the actual local magnetic variation. |
#168
On Apr 6, 12:31 am, Ron Natalie wrote:
wrote: On Apr 5, 5:37 am, "EridanMan" wrote: On Apr 4, 5:23 am, "Steven P. McNicoll" wrote: "EridanMan" wrote in message egroups.com... Why in gods name are VOR's Mag heading based? Tradition. Best answer I've heard yet ![]() Isn't the difference between your compass heading and the radial you are flying the drift? Knowing drift is pretty useful... The correction angle maybe. You aren't drifting at all if you are on the radial. Yes, that's what I mean, you are holding off "x" degrees of drift. That fact is very useful and given the choice between a true and magnetic VOR I think I would prefer magnetic for just that reason. You? Cheers MC |
#169
On Apr 6, 8:56 am, "Peter Dohm" wrote:
"RomeoMike" wrote in message ... wrote: Astro navigation, but it's still an angle away from a standard vector. So different sciences are using the same word with different meanings. However, you're of course correct that for magnetic navigation, declination and variation are the same thing. http://www.ngdc.noaa.gov/seg/geomag/faqgeom.shtml Kev Thanks to you, farr1220, and Peter. I always wondered in the back of my mind how the term declination came to mean variation. Now I'm ready to navigate the outer space :-) Hmmmm. I see that what I have been calling declination is called inclination on the NOAA site, so I will correct as appropriate. In view of my recollections of ground school, I believe that it might be least confusing to continue using the term deviation for the instrument error as installed, variation for the difference between true and magnetic north, and inclination for the angle between the lines of force and the horizontal--leaving the term declination unused. Yes and then aviators would be in perfect alignment with ocean naavigators who use variation and deviation. The conversion from true to compass heading makes a nice nemonic: timid virgins make dull company for TRUE (variation) MAGNETIC (deviation) COMPASS Cheers MC |
#170
![]() wrote in message ups.com... Yes, that's what I mean, you are holding off "x" degrees of drift. That fact is very useful and given the choice between a true and magnetic VOR I think I would prefer magnetic for just that reason. Most are neither. The GRB VORTAC was aligned to a magnetic variation of 1E in 1965. It's still there, but local magnetic variation is now 3W The airways are more closely aligned with true north than magnetic north. |
RANT! | wise purchaser | Owning | 2 | March 27th 07 10:04 PM |
Random thoughts 2 | Bill Daniels | Soaring | 6 | September 1st 06 05:37 AM |
A Jeppesen rant | Peter R. | Piloting | 4 | January 17th 05 03:54 AM |
Why didn't GWB [insert rant] | Jack | Military Aviation | 1 | July 15th 04 11:30 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
