Random thoughts 2
Old August 31st 06, 06:20 PM posted to rec.aviation.soaring
Bill Daniels
Default Random thoughts 2
Is it legal/possible/reasonable to install just Mode A transponder (No
altitude reporting)?
Whenever I hear "Traffic 12 O-clock 3 miles, altitude unknown" I look
EVERYWHERE. ahead. Might this provoke more visual scanning by aircraft
crews which could spot gliders without transponders in the same gaggle? A
case of one protecting all?
As a side benefit this would avoid the 24 months Mode C altimeter/encoder
check.
Bill Daniels
Old August 31st 06, 06:32 PM posted to rec.aviation.soaring
check.
Bill Daniels
Sure, anything is possible/ and/or reasonable. As far as legal goes,
remember if you have an instrument of any kind installed, you are
required by regulation to have it signed off by an A/P in your aircraft
log book. Additionally some reference to weight and bal. should also
be noted even if it's only to say, "no significant weight change." If
you put a transponder in your glider - either with or without an
encoder - it needs to be calibrated and so noted in your aircraft log
book. You are then required to have checked every twenty-four months.
If you are going to put a transponder in the glider, then spring for an
encoder - In for a penny, in for a pound and all that. Without the
encoder ATC as well as TCAS only gets azimuth and range. With the
encoder you get the third demension, altitude.
Sure beats ending up in Denver as a pitot cover on a B-767!
Billy Hill, Zulu
Old September 1st 06, 03:02 AM posted to rec.aviation.soaring
check.
Bill Daniels
I had my Mode C transponder in for it's 24 month checkup in April.
Fifty bucks!
How much are you paying for tows?
Matt Herron
Old September 1st 06, 06:02 AM posted to rec.aviation.soaring
Eric Greenwell[_1_]
BTIZ wrote:
BT
"flying_monkey" wrote in message
. . . snip . . .
If you put a transponder in your glider - either with or without an
Billy Hill, Zulu
Zulu,
Having owned a few junky older airplanes (like old Bonanzas) with only
Mode A transponders, I can't recall any requirement for calibration or
any recurrent inspection of these. If you're flying IFR, you have to
have a pitot/static check every two years, and if you have Mode C, you
have to have the encoder calibrated, but I wasn't aware of anything
other than that.
91.413(a) requires 24 month inspection of any transponder to be used in
airspace defined by 91.215
It makes no reference to VFR or IFR flight.
I can't find any reference in 91.413(a) to encoder calibration, and when
I have the required 2 year test done, only the encoder reading at field
elevation is checked. So, I don't think the encoder calibration check is
required for VFR operation. Do you know of a regulation requiring it?
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old September 1st 06, 06:37 AM posted to rec.aviation.soaring
BTIZ
news:chOJg.10062$XD1.1965@trnddc01...
BTIZ wrote:
BT
. . . snip . . .
Billy Hill, Zulu
Zulu,
other than that.
I can't find any reference in 91.413(a) to encoder calibration, and when I
Operation"
Eric, you are correct.. the encoder for altitude calibration is not in
91.413(a), that part is in 91.411 and 91.411 only refers to IFR
requirements, not VFR.
The 91.413(a) check verifies that the 4096 code dialed in is the code
transmitted and has nothing to do with altitude.
VFR only aircraft require 91.413 every 24 months..
IFR capable aircraft require 91.413 and 91.411 every 24 months..
So if you have the encoder and plan to go into Class A airspace... is the
91.411 required in a VFR only aircraft?
It's all part of the same check.. when you get the 91.413 done, and you have
an encoder, get the 94.411 done. The 91.411 also includes a pitot static
check.
BT
Thoughts on Oshkosh Jim Carter Piloting 0 August 1st 06 09:26 PM
Engine stumble, Any thoughts? Dave Owning 21 December 7th 05 01:43 AM
further thoughts about women suicide bombers Cub Driver Military Aviation 24 January 18th 04 08:52 AM
Random Hold Generator... Tina Marie Instrument Flight Rules 0 November 5th 03 05:21 PM
Thoughts at a funeral for a stranger matheson Military Aviation 2 July 4th 03 06:27 AM
