#161
On Jan 21, 7:13*am, Stefan wrote:
Beware!!! Eric Müller himself stressed that this applies *only* to aircraft with conventional elevator. It's actually more limited than that. For example, airplanes with aileron-rudder interconnects (springs/bungees, not hard links like the Ercoupe) will make it difficult (or impossible) depending on the design to determine which rudder is the one offering resistance (they both will, to different and varying degrees, since the boundary layer will have separated and the ailerons will be in the chaotic region). These interconnects are not, to my knowledge, still being designed in, but so much of the fleet is either old or built to old designs, so a lot of them are out there. Michael |
#162
On Mon, 21 Jan 2008 05:44:58 -0800 (PST), Michael
wrote: These interconnects are not, to my knowledge, still being designed in, but so much of the fleet is either old or built to old designs, so a lot of them are out there. The Malbu, Malibu Mirage, and the Meridian all have it. |
#163
On Mon, 21 Jan 2008 13:13:41 +0100, Stefan
wrote: There's nothing more dangerous than half-cooked advice by semi-skilled people. ' The alternative, of course, is to spin into the ground. Which would you rather try? Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com |
#164
Cubdriver schrieb:
There's nothing more dangerous than half-cooked advice by semi-skilled people. The alternative, of course, is to spin into the ground. Which would you rather try? The alrternative, of course, is to learn the correct spin recovery method for the particular plane you fly. Trying Müller-Beggs in a plane which doesn't respond to it *will* result in spinning into the ground. |
#165
On Jan 21, 2:44*pm, Michael wrote:
On Jan 21, 7:13*am, Stefan wrote: Beware!!! Eric Müller himself stressed that this applies *only* to aircraft with conventional elevator. It's actually more limited than that. *For example, airplanes with aileron-rudder interconnects (springs/bungees, not hard links like the Ercoupe) will make it difficult (or impossible) depending on the design to determine which rudder is the one offering resistance (they both will, to different and varying degrees, since the boundary layer will have separated and the ailerons will be in the chaotic region). You´re now into a region well beyond what a private pilot entering an accidental spin will be able to digest during the event, unless he gots quite a few hours of spin training. Bertie |
#166
On Jan 22, 10:17*am, Stefan wrote:
Cubdriver schrieb: There's nothing more dangerous than half-cooked advice by semi-skilled people. The alternative, of course, is to spin into the ground. Which would you rather try? The alrternative, of course, is to learn the correct spin recovery method for the particular plane you fly. Trying Müller-Beggs in a plane which doesn't respond to it *will* result in spinning into the ground. Um. Ok... bertie |
#167
On Jan 22, 10:33*am, Bertie the Bunyip
wrote: On Jan 22, 10:17*am, Stefan wrote: Cubdriver schrieb: There's nothing more dangerous than half-cooked advice by semi-skilled people. The alternative, of course, is to spin into the ground. Which would you rather try? The alrternative, of course, is to learn the correct spin recovery method for the particular plane you fly. Trying Müller-Beggs in a plane which doesn't respond to it *will* result in spinning into the ground. Um. Ok... bertie Bertie You seem to have some good advice and experience so I pay attention. I've long been a proponent of spin training and think Rich Stowell is one of the best around today for the training. My first spins came on my first solo back in about 1959 in a J-5. My instructor didn't seem too upset that I spent nearly a half hour doing spins before doing my obligatory 5 T/Go. Since then, as a flight instructor for the better part of 40+ years (original FAA CFI issuance was 1967), I've done spin training in a variety of aircraft and STILL teach spins when I get the chance. It really disturbs me that the FAA is constantly dumbing down the pilots of today and you can see it in the various publications. A lot of material is deleted that still applies but it is as if someone is afraid to teach it because it either scares them, or they simply don't know how to address it except by deletion. I'm senior instructor for a military training program and still fly between 70-95 hours a month in addition to helicopter training on the side. I keep pushing spin training for all who want it, and encourage those who are afraid of them to get the basic training to avoid getting killed with sloppy feet. Best Regards Ol S&B 24,000hrs and going strong (never thought I'd live this long either at 71) |
#168
"Ol Shy & Bashful" wrote:
It really disturbs me that the FAA is constantly dumbing down the pilots of today and you can see it in the various publications. A lot of material is deleted that still applies but it is as if someone is afraid to teach it because it either scares them, or they simply don't know how to address it except by deletion. With all due respect... The statistics computed for the Nall Reports and by the NTSB seem to show that the GA per-flight-hour accident rate has been generally on a very slow decline over the last decade or two. So if the FAA is "dumbing down" pilots, they aren't getting dumb fast enough to stem the decline in accident rates. Bottom line is that the declining accident rate doesn't seem to support the claim of "dumbing down". Or perhaps if it is true then maybe "dumb" pilots are safer pilots.... ;-) |
#169
Jim Logajan wrote:
"Ol Shy & Bashful" wrote: It really disturbs me that the FAA is constantly dumbing down the pilots of today and you can see it in the various publications. A lot of material is deleted that still applies but it is as if someone is afraid to teach it because it either scares them, or they simply don't know how to address it except by deletion. With all due respect... The statistics computed for the Nall Reports and by the NTSB seem to show that the GA per-flight-hour accident rate has been generally on a very slow decline over the last decade or two. So if the FAA is "dumbing down" pilots, they aren't getting dumb fast enough to stem the decline in accident rates. Bottom line is that the declining accident rate doesn't seem to support the claim of "dumbing down". Or perhaps if it is true then maybe "dumb" pilots are safer pilots.... ;-) While I tend to agree with you, a certain amount of that decline is probably the result of less new pilots coming into the system. This will have the effect of making the average experience of those pilots in the system to go up. |
#170
On Jan 22, 11:31*am, Bertie the Bunyip wrote:
It's actually more limited than that. *For example, airplanes with aileron-rudder interconnects (springs/bungees, not hard links like the Ercoupe) will make it difficult (or impossible) depending on the design to determine which rudder is the one offering resistance (they both will, to different and varying degrees, since the boundary layer will have separated and the ailerons will be in the chaotic region). You´re now into a region well beyond what a private pilot entering an accidental spin will be able to digest during the event, unless he gots quite a few hours of spin training. That's rather the point. Muller-Beggs calls for the pilot to feel the rudders, and to press on whichever rudder offers resistance. Unfortunately, in an airplane with interconnected rudder and ailerons, both rudders will offer varying resistance in the stall/spin. An experienced pilot with sensitive feet might be able to sort it out, but he probably wouldn't get into the situation in the first place unless intentionally flirting with that edge of the envelope, and in any case would know the correct recovery. So yes, that's my point - for a typical private pilot entering an accidental spin in an airplane equipped with rudder-aileron interconnects, the Muller-Beggs recovery won't work, even though the elevator is conventional. Thus my point that it is even more limited than Stefan noted. Michael |
spins from coordinated flight | Todd W. Deckard | Piloting | 61 | December 29th 07 01:28 AM |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
Spins in Libelles 301 & 201 | HL Falbaum | Soaring | 9 | February 10th 04 06:12 PM |
Thanks for the Spins Rich | David B. Cole | Aerobatics | 17 | October 26th 03 08:37 AM |
