Andy,
both GPS failure AND vacuum failure together is a very rare event. Yes, but he said it was a VFR GPS only. -- Thomas Borchert (EDDH) |
You wouldn't actually recommend that your student, after passing the check ride,
fly that airplane in IMC, would you? On 7/19/2005 11:54 PM, Rugby51 wrote the following: I am a relatively new CFII looking for some advice. I am starting an instrument student in a 172 that is bare bones IFR. The plane has a single nav with glideslope, a VFR GPS installation, and no ADF or DME. I haven't flown the plane on an IFR flight yet, but it seems that the way to make it work is to just have fast fingers, and good SA. Any tips on how to navigate/teach in this airplane? I've been looking over local approaches, flying them on paper. If, for instance, a VOR approach uses a cross radial from another facility to ID the FAF then what is the best way to proceed? My plan would be work hard to nail the approach course as early as possible, and have the cross-radial VOR in standby. Then I could flip the nav to the cross-radial, spin the OBS and see where I was, then flip back to the approach VOR/course. Of course, knowing the distance to the cross-radial VOR could be helpful. Using the 60nm = 1nm per degree of deflection on the CDI could give ete to the fix. Am I approaching this correctly? Any advice, tips, techniques would be greatly appreciated. Thanks! |
Well, actually, I would. What is the percentage increase in risk flying with a single nav, versus dual navs? From a risk management standpoint, I will talk with my student about planning flights that leave an "out" should the nav fail.
We are in Western Washington, home of the stable, moist airmass. Would I launch in this plane on a fall afternoon with broken/overcast at 3500' and layers up to the FL's? Yes! Would I go at night, in February, with ceilings at 2000', and a negligible temp spread, with conditions being similar over all of Western Washington/Oregon? Definately not. Quote:
I was thinking of it more in a workload sense than worrying about radio failure.
If it is a VFR GPS without a moving map, then it would seem to me that the effort to maintain good situational awareness would be very large. Single pilot, with no one backing me up, I would certainly worry about it if it were me in that airplane. It probably depends on the airspace, too. I fly in & around around the Minneapolis Bravo, and Approach is very busy. In fact today I was flying safety pilot with a friend and twice we were deliberately vectored through a final approach course because of traffic. We also flew the published hold for the STP ILS 14, which is a VOR radial intersection alternatively defined by DME off one of the VORs. I would not want to have tried to keep SA track of all that with a single VOR, no DME airplane. I hope your nav is at least a flip-flop! :-) On 7/21/2005 10:07 AM, Rugby51 wrote the following: Well, actually, I would. What is the percentage increase in risk flying with a single nav, versus dual navs? From a risk management standpoint, I will talk with my student about planning flights that leave an "out" should the nav fail. We are in Western Washington, home of the stable, moist airmass. Would I launch in this plane on a fall afternoon with broken/overcast at 3500' and layers up to the FL's? Yes! Would I go at night, in February, with ceilings at 2000', and a negligible temp spread, with conditions being similar over all of Western Washington/Oregon? Definately not. Mitty Wrote: You wouldn't actually recommend that your student, after passing the check ride, fly that airplane in IMC, would you? On 7/19/2005 11:54 PM, Rugby51 wrote the following:- I am a relatively new CFII looking for some advice. I am starting an instrument student in a 172 that is bare bones IFR. The plane has a single nav with glideslope, a VFR GPS installation, and no ADF or DME. I haven't flown the plane on an IFR flight yet, but it seems that the way to make it work is to just have fast fingers, and good SA. Any tips on how to navigate/teach in this airplane? - |
Amazingly, the workload is not too bad if you use the right procedures. No way would I fly a Mooney or Bonanza so equipped in hard IFR, but for a Skyhawk-class airplane it works. The plane is so stable and so benign that if you slow it down and drop some flaps, things happen slowly enough to manage it. I still sometimes fly a TriPacer IFR - and it has only one nav-com (not even a flip-flop) and a VFR GPS. It works - and it works in the busy airspace of Houston. Michael |
Find someone with a Frasca or other trainer to teach in. Then go into the
airplane. Keep the GPS off. Teach the student on the ground and in a trainer first. Even using a pc is better than nothing. Then go up in the plane. "Rugby51" wrote in message ... I am a relatively new CFII looking for some advice. I am starting an instrument student in a 172 that is bare bones IFR. The plane has a single nav with glideslope, a VFR GPS installation, and no ADF or DME. I haven't flown the plane on an IFR flight yet, but it seems that the way to make it work is to just have fast fingers, and good SA. Any tips on how to navigate/teach in this airplane? I've been looking over local approaches, flying them on paper. If, for instance, a VOR approach uses a cross radial from another facility to ID the FAF then what is the best way to proceed? My plan would be work hard to nail the approach course as early as possible, and have the cross-radial VOR in standby. Then I could flip the nav to the cross-radial, spin the OBS and see where I was, then flip back to the approach VOR/course. Of course, knowing the distance to the cross-radial VOR could be helpful. Using the 60nm = 1nm per degree of deflection on the CDI could give ete to the fix. Am I approaching this correctly? Any advice, tips, techniques would be greatly appreciated. Thanks! -- Rugby51 |
| Thread Tools | |
| Display Modes | |
| Single Place L-33 Rental now available STANTON MN | Soar Stanton MN | Soaring | 0 | May 14th 05 01:52 AM |
| idea: single occupant VTOLs.. (will it fly?) | Eddie | Home Built | 5 | April 20th 04 04:05 PM |
| single pilot ifr trip tonight | Guy Elden Jr. | Instrument Flight Rules | 187 | November 24th 03 11:18 PM |
| Is taking off on single mag bad for engine | flyer | Home Built | 10 | September 21st 03 10:43 PM |
| WANTED: partnership, rental or club with fast single or light twin in San Diego | Jim McGarvie | Aviation Marketplace | 0 | September 13th 03 04:55 PM |
