OK, FAR Lawers we need your help!
Old August 29th 04, 02:35 AM
C J Campbell
ink.net...
"C J Campbell" wrote in message
See AIM 1-1-20c.7. WAAS may be used as a stand-alone
system anywhere in the NAS.
GPS cannot substitute for a VOR.
Odd, then, that FAAO 7110.65 allows controllers to issue airways routing
to
GPS-equipped aircraft when the navaids defining those airways are not in
service.
Yeah, I noticed that contradiction, too. I regularly use McCord VOR as a
waypoint for airway routing even though the thing has been OPTS for years.
Old August 28th 04, 06:57 AM
C J Campbell
k.net...
Recently the COE VOR was notamed OTS. Coincedent with this the KSZT
LOC/DME
was notamed NA. The explanation given was that the COE VOR was nessasary
to
fly the tranition (COE is the IAF) and the missed approach (the missed
ends
with a hold at the COE VOR). I contend that GPS can substitute for the
VOR
but I can't find it witten down anywhere. The KSZT LOC, DME and ADF are
all
working properly. Our question is: Was the KSZT LOC/DME approach
improperly NOTAMed NA? Can you cite a source? Remember we are talking
about substituting GPS for the VOR to fly the transition, we are not
talking
about substituting for the LOC.
AIM 1-1-19 says:
f. Use of GPS in lieu of ADF and DME
1. Subject to the restrictions below, operators in the U.S. NAS are
authorized to use GPS equipment certified for IFR operations in place of ADF
and/or DME equipment for en route and terminal operations. For some
operations there is no requirement for the aircraft to be equipped with an
ADF or DME receiver, see subparagraphs f6(g) and (h) below. The ground-based
NDB or DME facility may be temporarily out of service during these
operations. Charting will not change to support these operations.
There is no provision for GPS to be used in lieu of VOR. 1-1-20 addresses
the use of WAAS. WAAS eliminates the requirement for backup navigation
systems and may be used stand-alone. You may, of course, use GPS to navigate
to a location that happens to be a VOR, just as you may use GPS to navigate
to any other point, but if you have no VOR you cannot use it for an
approach. If you have WAAS you may use it for any approach authorized for
WAAS (these approaches are annotated as such) and need no ground radios at
all.
Old August 28th 04, 02:37 PM
Mike Rapoport
news
k.net...
LOC/DME
nessasary
to
ends
VOR
all
talking
AIM 1-1-19 says:
ADF
ground-based
addresses
navigate
navigate
all.
So, if I had WAAS and nothing else, I could fly the transition but the VOR
has to be operational even though I don't have a VOR reciever onboard?
MU-2
Old August 28th 04, 04:21 PM
C J Campbell
k.net...
No. You can't fly the VOR unless you have VOR on board and the VOR on the
ground is operational. You may substitute WAAS for the VOR if the approach
has been approved for WAAS.
Old August 28th 04, 07:01 PM
Ron Rosenfeld
On Sat, 28 Aug 2004 08:21:21 -0700, "C J Campbell"
That is directly contrary to what is in the AIM with regard to overlay
approaches, whether or not WAAS is mentioned.
" h. GPS Approach Procedures
.... During these GPS approaches [referring to overlay approaches],
underlying ground-based NAVAIDs are not required to be operational and
associated aircraft avionics need not be installed, operational, turned on
or monitored "
--ron
Old August 28th 04, 07:31 PM
Steven P. McNicoll
"Ron Rosenfeld" wrote in message
approach
or monitored "
That's an overlay approach, a "VOR or GPS RWY 24" approach, for example.
For an approach like that you don't need a VOR, but you would for a "VOR RWY
24" approach.
Old August 28th 04, 07:03 PM
Ron Rosenfeld
On Fri, 27 Aug 2004 22:57:15 -0700, "C J Campbell"
There is for approaches. See 1-1-19 h.
"As the production of stand-alone GPS approaches has progressed, many of
the original overlay approaches have been replaced with stand-alone
procedures specifically designed for use by GPS systems. The title of the
remaining GPS overlay procedures has been revised on the approach chart to
"or GPS" (e.g., VOR or GPS RWY 24). Therefore, all the approaches that can
be used by GPS now contain "GPS" in the title (e.g., "VOR or GPS RWY 24,"
"GPS RWY 24," or "RNAV (GPS) RWY 24"). During these GPS approaches,
or monitored (monitoring of the underlying approach is suggested when
equipment is available and functional). Existing overlay approaches may be
requested using the GPS title, such as "GPS RWY 24" for the VOR or GPS RWY
24".
--ron
Old August 28th 04, 07:33 PM
Steven P. McNicoll
24".
If you're using GPS to fly a "VOR or GPS RWY 24" you're not substituting GPS
for the VOR. The approach can be flown with either one.
Old August 29th 04, 02:16 AM
Mike Rapoport
OK, now it gets interesting! The VOR is still NOTAMed OTS but the KSZT
LOC/DME approach isn't!
Any thoughts?
MU-2
Old August 29th 04, 11:16 AM
Ron Rosenfeld
On Sat, 28 Aug 2004 18:33:56 GMT, "Steven P. McNicoll"
Exactly the point.
--ron
