Metric Soaring
Old September 15th 07, 06:00 AM posted to rec.aviation.soaring
Eric Greenwell
Default Metric Soaring
Nyal Williams wrote:
At 03:30 15 September 2007, Marc Ramsey wrote:
snip
That does explain the change in airspeed units, the
change to knots on
the vario still seems a bit 'radical' for glider pilots
to pull it off
that quickly...
Does this have something to do with US pilots' copying
the panels of the Europeans, who were winning big time?
Europeans were using knots, not m/s? Now that's weird! There was a
transition period, when you could order a Ball vario (and probably other
US varios) in fpm or knots. The only difference was the label - the
vario, including markings, was otherwise identical.
Old September 15th 07, 12:40 PM posted to rec.aviation.soaring
Maciek
Użytkownik "Paul Hanson"
napisał w wiadomo¶ci
Why do metric variometers read in m/s, instead of kph
when the metric airspeed is in kph? Would it not make
more sense to use kph on the vario too so quick mental
L/D calculations could be done (for those who do not
use a flight computer etc to think for them)?
And why do english vaariometers read in ft/min, when the english airspeed is
in knots?
multiply the m/s by 4, and then reduce the result by 1/10 and you will get
the exact value in km/h if you need to.
Old September 15th 07, 02:47 PM posted to rec.aviation.soaring
John H. Campbell
Yes, my understanding is that (e.g. from Winter) the vario is the same
with alternative label plates, 1,000 fpm = 10 kt = 5 m/s (within 1%).
Old September 15th 07, 04:09 PM posted to rec.aviation.soaring
Mark Dickson
At 11:42 15 September 2007, MacIek wrote:
They are in knots. Although I would guess that most
people think of the climb rate as hundreds of feet
per minute. 1kt is 100' per min.
in knots?
Old September 15th 07, 04:24 PM posted to rec.aviation.soaring
Mitch
On Sep 14, 9:27?pm, "Bill Daniels" bildan@comcast-dot-net wrote:
Actually, I think it's one minute of latitude equals a nautical mile - works
great at a chart table with dividers but not much use in a glider cockpit.
Bill, It's one minute of LONGATUDE that equals a nautical mile.
minutes of latitude vary in spacing depending how far north or south
they go. Just got my Navigator wings, so I guess I can correct
you. :-)
-EX
Old September 15th 07, 04:37 PM posted to rec.aviation.soaring
Greg Arnold
Yikes! What are you going to be navigating?
Go north or south one nautical mile, and you have moved a minute of
latitude.
Move a minute of longitude, and you have moved east or west, and the
distance varies how far north or south you are.
you. :-)
-EX
Old September 15th 07, 05:51 PM posted to rec.aviation.soaring
Tony Verhulst
Bill, It's one minute of LONGATUDE .....
Just got my Navigator wings, so I guess I can correct you. :-)
Then why don't ya know how to spell "Longitude"? :-)
Tony V.
Old September 15th 07, 06:03 PM posted to rec.aviation.soaring
Mitch
Tony V.
Both points above, absolutely correct by Tony and Greg. LOL It was a
LONG night last night, so I'm gonna have to eat crow in public on this
one. It has been a while since I have actually gotten a set of
dividers out. We always measured mileage by spanning our dividers
north and south along a line of longitude which would be measuring
latitude. The misspelling...I blaim on the fact that my spell checker
does not correct words in all caps. :-P I'm gonna go crawl in a hole
now, and continue recovery from my hangover and prevent future idiotic
postings! :-) see ya!
Old September 16th 07, 12:10 AM posted to rec.aviation.soaring
Nyal Williams
you. :-)
Then why don't ya know how to spell 'Longitude'? :-)
Tony V.
LOL It was a
in public on this
a set of
our dividers
be measuring
my spell checker
go crawl in a hole
future idiotic
Don't BLAME you, Mitch! grin
Nyal
Old September 16th 07, 02:08 AM posted to rec.aviation.soaring
Ralph Jones[_2_]
Tony V.
Well, to get all pedantic, there have been several definitions of the
nautical mile, one of which was one minute of longitude at the
equator -- which has the advantage of being unambiguous since the
equator is a circle to very high precision. If you define it as a
minute of latitude you still have to specify the latitude where you
make the measurement, because the earth is not exactly spherical;
England defined it for a time as one minute of latitude measured at
the latitude of London.
Today it's simply defined as exactly 1852 meters, but "the arc length
subtended by one minute of latitude" is just peachy for navigational
purposes.
rj
Metric Instruments Roy Bourgeois Soaring 29 May 27th 13 01:53 PM
VW engines by metric AP [email protected] Home Built 15 August 7th 07 03:48 PM
Metric Instruments? AFSax Soaring 14 August 24th 05 02:52 PM
Off topic - Metric Nuts Paul Remde Soaring 8 May 5th 04 11:15 PM
Wanted - Metric Altimeters RHWOODY Soaring 0 September 13th 03 10:20 PM
