Matthew Speed wrote in
: On Sun, 18 Nov 2007 15:00:26 +0100, Stefan wrote: I've just stumbled over this picture. Does anybody know what kind of engine this is? http://www.airliners.net/open.file?id=0537804&size=M Looking at that picture it seems to me that it would much easier to damage that engine with the blades exposed like that. Given the rate at which turbine engines rotate wouldn't the engine be subjected to extreme stresses if one of the blades were to be damaged? Well, the blades go considerably slower than a turbine does! All the same, they're pretty fast compared to a standard prop. If a jet engine loses a fan blade it's not a good thing either. You've got to shut down reasonably quickly. It'd be about the same for this engine, I would think Bertie |
One thing that would make me nervous, would be flying an engine like that,
if a blade turned loose for some reason. It would bring uncontained failure a new meaning. -- Jim in NC |
![]() "Matthew Speed" wrote in message ... On Sun, 18 Nov 2007 15:00:26 +0100, Stefan wrote: I've just stumbled over this picture. Does anybody know what kind of engine this is? http://www.airliners.net/open.file?id=0537804&size=M Looking at that picture it seems to me that it would much easier to damage that engine with the blades exposed like that. Given the rate at which turbine engines rotate wouldn't the engine be subjected to extreme stresses if one of the blades were to be damaged? I was always told that the engine on a prop plane would probably get ripped out of the mounts if a prop lost a blade so I don't think it is good on any engine! |
"Darkwing" theducksmail"AT"yahoo.com wrote in
: "Matthew Speed" wrote in message ... On Sun, 18 Nov 2007 15:00:26 +0100, Stefan wrote: I've just stumbled over this picture. Does anybody know what kind of engine this is? http://www.airliners.net/open.file?id=0537804&size=M Looking at that picture it seems to me that it would much easier to damage that engine with the blades exposed like that. Given the rate at which turbine engines rotate wouldn't the engine be subjected to extreme stresses if one of the blades were to be damaged? I was always told that the engine on a prop plane would probably get ripped out of the mounts if a prop lost a blade so I don't think it is good on any engine! It will. one of the guys in my EAA chapter lost a blade on his Tailwind. The prop was an "experimental" McCauley clip tip prop IIRC. The mounts broke completely, but the cowling, throttle cable and what not kept the engine on board. He deadsticked back to the field. The Navy called up asking f anyone owned the blade later that day. it had landed in someones back yard just missing the lady of the house as she was hanginr her laundry! It's happened many times over the years, in fact. There was one in england where the engine on a Navajo shed a blade, the engine came off, and the engine went over the top of the fuselage and took out the second engine. the guy succesfully deadsticked the airplane into a field.. Bertie Bertie |
![]() "Bertie the Bunyip" wrote in message .. . "Darkwing" theducksmail"AT"yahoo.com wrote in : "Matthew Speed" wrote in message ... On Sun, 18 Nov 2007 15:00:26 +0100, Stefan wrote: I've just stumbled over this picture. Does anybody know what kind of engine this is? http://www.airliners.net/open.file?id=0537804&size=M Looking at that picture it seems to me that it would much easier to damage that engine with the blades exposed like that. Given the rate at which turbine engines rotate wouldn't the engine be subjected to extreme stresses if one of the blades were to be damaged? I was always told that the engine on a prop plane would probably get ripped out of the mounts if a prop lost a blade so I don't think it is good on any engine! It will. one of the guys in my EAA chapter lost a blade on his Tailwind. The prop was an "experimental" McCauley clip tip prop IIRC. The mounts broke completely, but the cowling, throttle cable and what not kept the engine on board. He deadsticked back to the field. The Navy called up asking f anyone owned the blade later that day. it had landed in someones back yard just missing the lady of the house as she was hanginr her laundry! It's happened many times over the years, in fact. There was one in england where the engine on a Navajo shed a blade, the engine came off, and the engine went over the top of the fuselage and took out the second engine. the guy succesfully deadsticked the airplane into a field.. Bertie I was told that if the engine came out that you would probably be so far out of CG you would crash tail first. So that surprises me that the Navajo made it down under control. |
: "Bertie the Bunyip" wrote in message .. . "Darkwing" theducksmail"AT"yahoo.com wrote in : "Matthew Speed" wrote in message ... On Sun, 18 Nov 2007 15:00:26 +0100, Stefan wrote: I've just stumbled over this picture. Does anybody know what kind of engine this is? http://www.airliners.net/open.file?id=0537804&size=M Looking at that picture it seems to me that it would much easier to damage that engine with the blades exposed like that. Given the rate at which turbine engines rotate wouldn't the engine be subjected to extreme stresses if one of the blades were to be damaged? I was always told that the engine on a prop plane would probably get ripped out of the mounts if a prop lost a blade so I don't think it is good on any engine! It will. one of the guys in my EAA chapter lost a blade on his Tailwind. The prop was an "experimental" McCauley clip tip prop IIRC. The mounts broke completely, but the cowling, throttle cable and what not kept the engine on board. He deadsticked back to the field. The Navy called up asking f anyone owned the blade later that day. it had landed in someones back yard just missing the lady of the house as she was hanginr her laundry! It's happened many times over the years, in fact. There was one in england where the engine on a Navajo shed a blade, the engine came off, and the engine went over the top of the fuselage and took out the second engine. the guy succesfully deadsticked the airplane into a field.. Bertie I was told that if the engine came out that you would probably be so far out of CG you would crash tail first. So that surprises me that the Navajo made it down under control. Well, only one of them came off. the other just quit. You're right, though .On a single you would have little chance. There was a Stearman that the engine came off of and they did make it, or so the story went. The Navajo wasn't all that long ago. there must be some pics somewhere. Bertie |
![]() "Darkwing" wrote I was always told that the engine on a prop plane would probably get ripped out of the mounts if a prop lost a blade so I don't think it is good on any engine! I think it's clear that it does happen, but it is also true that many engines lose prop blades, and the engine stays with the airplane. I'll bet many more stay, than depart. -- Jim in NC |
"Morgans" wrote in
: "Darkwing" wrote I was always told that the engine on a prop plane would probably get ripped out of the mounts if a prop lost a blade so I don't think it is good on any engine! I think it's clear that it does happen, but it is also true that many engines lose prop blades, and the engine stays with the airplane. I'll bet many more stay, than depart. Not so sure. Most I've heard of either had the engine depart completely or be left supported by the cowling or plumbing.. Bertie |
![]() "Bertie the Bunyip" wrote Not so sure. Most I've heard of either had the engine depart completely or be left supported by the cowling or plumbing.. Sure, but you don't hear about the ones that turn out with no problems. If they don't injure anyone severely, and don't tear up the equipment too badly, they don't even end up with a report in the NTSB database, or calling out the FAA. -- Jim in NC |
On Nov 18, 7:00 am, Stefan wrote:
I've just stumbled over this picture. Does anybody know what kind of engine this is?http://www.airliners.net/open.file?id=0537804&size=M This was the engine that was going to be used on the 7J7 by Boeing. The 7J7 was a developmental program for an airplane about the size of a 727 that would have become the 777, but was canceled. Boeing later started the 767-X program with a much larger airplane than the 7J7 that eventually became the 777 that is currently in production. Dean |
Unusual Sighting (What was that?) | Kyle Boatright | Home Built | 14 | November 15th 07 01:34 AM |
Unusual Distractions | Ol Shy & Bashful | Piloting | 126 | July 22nd 07 02:24 AM |
Unusual classified ad | Adam Aulick | Owning | 22 | August 10th 05 06:04 PM |
Unusual ECI Cylinder | [email protected] | Home Built | 4 | July 7th 05 01:27 AM |
Unusual Procedure at DFW | Toks Desalu | Piloting | 9 | December 17th 03 05:27 PM |
