Flatlander heading to Boulder, CO -- need sage advice
Old July 17th 06, 02:36 AM posted to rec.aviation.piloting
Blanche Cohen
Default Flatlander heading to Boulder, CO -- need sage advice
Doug wrote:
Just take off in Atlanta and climb to 6500'. Stay at that altitude and
when you get to Boulder, you will be at pattern altitude! (actually
pattern altitude is 6300'). Run at full power. Lean for best rpm (at
6300'). See how far out the lean knob is? That is how far out it should
be for takeoff too (plus 3 half turns in). We lean on the ground at
runup for takeoffs at these altitudes. Learn how to do that if you
don't know how. This time of year is bumpy below the cumulus and if we
have rain, it is thunderstorms you can see and go around. So go around
them. The weather is good for flying in the summer in Colorado. Have
fun and see ya!
By September, the Tstorms will be gone (we hope!) but it'll still
be a bit warm. Mid-Kansas, go up to 8500 -- air will be
smoother (usually), and a great view of the Rockies.
Old July 17th 06, 02:38 AM posted to rec.aviation.piloting
Blanche Cohen
Jim Macklin wrote:
Just be aware that on a hot day in the Denver area, 35C is
possible, even higher on the air above the paved runway.
That can make the density altitude near 10,000 feet on the
surface. Take-off performance and service ceilings will be
reduced. Climb gradient will be shallow. Pack like a
backpacker. If you land with a lot of luggage, remember for
the return home, UPS and FedEx can reduce you load of
non-essentials for the departure for home.
Today, it was 37-40C depending where you were.
Old July 17th 06, 03:52 AM posted to rec.aviation.piloting
Jim Macklin
It was 40 C here in Wichita today, MSL 1332, DA about 4,500.
"Blanche Cohen" wrote in message
is
be
for
Old July 18th 06, 02:40 AM posted to rec.aviation.piloting
Blanche Cohen
is
be
for
True, Jim. But around here, 37C means 9500 DA on the ground.
And it's why I drove to Leadville for sightseeing, while many
of the Colorado Pilots Assoc. Flew to Montrose (MTJ) for
a weekend flyin. Due to DA, I couldn't take my regular 2.2 hour
flight (couple of passes, no big deal -- usually), and the
low-er-land route would have taken me 5 hours (with a stop for
fuel). Not worth it. I've flown into Leadville, but never
got away from the airport. This time -- typical
tourist, and loved it.
Old July 18th 06, 03:06 AM posted to rec.aviation.piloting
Jim Macklin
The point is that whenever the ambient temperature is above
ISA standard, the density altitude and thus aircraft
performance will be worse. Hot days in Wichita is like a
standard day in Denver and a hot day in Denver is like
Leadville. With a non-turbocharged engine, the service
ceiling may be at the surface.
James H. Macklin
ATP,CFI,A&P
4,500.
| | Jim Macklin
35C
| is
runway.
| the
will
| be
remember
| for
ground.
many
hour
for
Gageteers, we need a digital heading sensor Bill Daniels Soaring 32 June 26th 04 06:07 AM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
