Night VFR following highways
Old February 1st 08, 11:16 PM posted to rec.aviation.student,rec.aviation.piloting
Rich Ahrens[_2_]
Default Night VFR following highways
gatt wrote:
Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch
through most of Oregon looks like somebody drew a straight line with a
pencil across the landscape. If you were flying from Portland (possible
Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow
the freeway the entire route.
I followed a highway up to Alaska. In daylight,however.
Old February 2nd 08, 12:20 AM posted to rec.aviation.student, rec.aviation.piloting
paul k. sanchez
On Feb 1, 1:28*pm, Mxsmanic wrote:
Is it a bad idea to fly VFR at night and navigate by following highways? *At
night outside large cities, there doesn't seem to be much else that's visible.
It seems to me that if you can clearly see the highway, it can guide you and
you can get a good idea of where you are with respect to terrain, so it should
work. *Are there hidden dangers in this? *Do night VFR pilots ever/often
navigate by following highways? *What other forms of visual navigation are
usable at night?
I would suggest doing a flight then at night so you could find out.
Perhaps along some mountain passes with 3.1 statue mile visibility,
with appropriate distance from clouds. Please lets us know after you
done this flight.
Old February 2nd 08, 02:16 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
gatt writes:
My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow
Roads " (or rivers)
There is a sobering story right along those lines at
http://www.aopa.org/pilot/never_again/2008/na0801.html
I find it interesting that the author says this VFR flight scared him more
than any of his combat missions in Vietnam.
You'd still use your VFR navigation aids and checkpoints to make sure know
how far you are enroute, and also to avoid controlled airspace, etc, but
having that road, railroad, river makes for a more-enjoyable flight.
Good. I wanted to make sure I'm not missing some risk or danger to following
highways. From the article above I learned that things like wires and cables
are a real risk if you're very close to the highway, but only a helicopter
would be that low.
Old February 2nd 08, 02:18 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
writes:
Anyone flying at night low enough to worry about power lines in
route is an idiot.
Here is the "idiot's" story:
  #29
Old February 2nd 08, 02:19 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
paul k. sanchez writes:
done this flight.
I've done that, but with radio navigation aids. Even so, it was pretty
harrowing.
  #30
Old February 2nd 08, 02:24 AM posted to rec.aviation.student, rec.aviation.piloting
usable at night?
About the only reason to follow highways (other than it just happens to
go where you want to go) at night is you are guaranteed that there is
nothing directly above the highway (such as a mountain peak), which is
handy for going through things like passes on dark nights and areas
dotted with high peaks.
However, the only way one would know visually that they are really
over most highways at night is from the real lights of real traffic.
Since there is no real traffic on your simulated highways with real
headlights, why would you care?
Jim Pennino
Remove .spam.sux to reply.
Unless the highway goes through a tunnel....... : (
Arizona Highways magazine on soaring, flight [email protected] Soaring 0 December 20th 06 03:05 AM
Night Flying. How many PPSEL pilots excersie night priveledges? [email protected] Piloting 42 December 16th 06 04:51 PM
Night lights, night flights, OLC and records Denis Soaring 19 October 9th 06 11:51 PM
Hood and sim work at night loggable as night time? Ron Garret Piloting 12 September 9th 06 02:15 AM
FS2004 scenery which shows roads and highways? John Doe Simulators 9 March 25th 04 08:36 AM
