Night VFR following highways
Old February 1st 08, 06:28 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Default Night VFR following highways
Is it a bad idea to fly VFR at night and navigate by following highways? At
night outside large cities, there doesn't seem to be much else that's visible.
It seems to me that if you can clearly see the highway, it can guide you and
you can get a good idea of where you are with respect to terrain, so it should
work. Are there hidden dangers in this? Do night VFR pilots ever/often
navigate by following highways? What other forms of visual navigation are
usable at night?
Old February 1st 08, 06:57 PM posted to rec.aviation.student,rec.aviation.piloting
Ross
usable at night?
Why would you want to when VORs ang GPSs are available? However, on a
clear night you can see the far away town lights. You just need to be
sure that the lights you see are the town you want. I'll stay with my
GPS for navigation.
Regards, Ross
C-172F 180HP
KSWI
Old February 1st 08, 07:03 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Ross writes:
Mainly just for practice, in case the radio navigation fails or something.
However, on a
GPS for navigation.
What if the GPS stops working?
Old February 1st 08, 07:27 PM posted to rec.aviation.student,rec.aviation.piloting
Bertie the Bunyip[_25_]
Mxsmanic wrote in
highways? At night outside large cities, there doesn't seem to be
much else that's visible. It seems to me that if you can clearly see
the highway, it can guide you and you can get a good idea of where you
are with respect to terrain, so it should work. Are there hidden
dangers in this? Do night VFR pilots ever/often navigate by following
highways? What other forms of visual navigation are usable at night?
I use the reflection of the table lamp on my monitor screen.
Bertie
Old February 1st 08, 07:28 PM posted to rec.aviation.student,rec.aviation.piloting
Ross wrote in
you are with respect to terrain, so it should work. Are there hidden
following highways? What other forms of visual navigation are usable
at night?
If you're flying a no radio airplane?
Bertie
Mxsmanic wrote in
Ross writes:
something.
Why, you don't fly.
Or is your latest terorist target a night target?
Bertie
Old February 1st 08, 07:57 PM posted to rec.aviation.student,rec.aviation.piloting
Ross
Bertie the Bunyip wrote:
Ross wrote in
at night?
Bertie
Then I guess I would follow roads, but might buy a handheld GPS if I was
going to do a lot of this.
Regards, Ross
C-172F 180HP
KSWI
Old February 1st 08, 08:22 PM posted to rec.aviation.student,rec.aviation.piloting
Gig 601XL Builder[_2_]
Please note that MX is xposting to R.A.S.
Old February 1st 08, 08:35 PM posted to rec.aviation.student,rec.aviation.piloting
usable at night?
About the only reason to follow highways (other than it just happens to
go where you want to go) at night is you are guaranteed that there is
nothing directly above the highway (such as a mountain peak), which is
handy for going through things like passes on dark nights and areas
dotted with high peaks.
However, the only way one would know visually that they are really
over most highways at night is from the real lights of real traffic.
Since there is no real traffic on your simulated highways with real
headlights, why would you care?
Jim Pennino
Remove .spam.sux to reply.
Old February 1st 08, 08:45 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
writes:
Actually, the sim does put traffic on the highways.
Arizona Highways magazine on soaring, flight [email protected] Soaring 0 December 20th 06 03:05 AM
Night Flying. How many PPSEL pilots excersie night priveledges? [email protected] Piloting 42 December 16th 06 04:51 PM
Night lights, night flights, OLC and records Denis Soaring 19 October 9th 06 11:51 PM
Hood and sim work at night loggable as night time? Ron Garret Piloting 12 September 9th 06 02:15 AM
FS2004 scenery which shows roads and highways? John Doe Simulators 9 March 25th 04 08:36 AM
