#41
"Stan Gosnell" wrote in message ... And the price for a VOR receiver is sane? It's just a simple radio No doubt all avionics are expensive -- the problem is that a GPS-only world would *force* people who have invested in an IFR-capable airplane to now spend *even more* money on a new upgrade. Actually, this would be even a worse hit because the value of existing non-GPS navigation equipment would instantly depreciate to near-zero. It would be even worse on top of that because of the need for ongoing GPS database subscriptions. Multiply this triple financial hit by however many airplanes are in a given flight school and lots of those airplanes will just be converted to VFR use. Not only that, but many pilots who own instrument airplanes flown only occasionally IFR will decide it is just not worth the effort and expense and will revert to being VFR-only pilots of VFR-only airplanes. IFR would become notably less common in GA, and that would be a shame. -- Richard Kaplan, CFII www.flyimc.com |
#42
"Roy Smith" wrote in message ... Why does radar not meet that requirement? Is your goal to keep air traffic moving, or just to get aircraft down on the ground at the nearest usable airport? If the latter, my guess is radar would be sufficient. What happens in areas of the country which have no radar coverage? Everyone in the area of GPS failure climbs by dead reckoning to an altitude high enough to achieve radar coverage and we hope there are no mid-airs in the process and we hope there are no icing accidents in the process? Then everyone gets vectored to the precious few airports with ASR approaches and waits their turn to fly an ASR approach? And while the lucky first few airplanes are being vectored for their ASR approaches, ATC has to give every other airplane in the sky radar vectors for each turn in each airplane's hold? Do we really have the ATC personnel and radio frequency resources to accomplish this? If we really were to have a GPS failure on a low IMC day, I think it would be very questionable to think we could get all the planes down without either having midair collisions or planes running out of fuel. -- Richard Kaplan, CFII www.flyimc.com |
#43
"Stan Gosnell" wrote in message ... It always comes down to money. Always. And keeping obsolete systems working is hugely expensive, & it won't happen. End of story. A very reasonable and economically practical compromise would be to keep the Loran system up and running and approve Loran for emergency IFR use in the event of GPS outage. The cost of maintaining the Loran system is pocket change compared wtih maintaining the GPS system. An even better compromise would be to decommission some ground-based navaids but leave at least enough VORs and ILSs functional so as to assure their reasonable availability for an emergency approach anywhere in the country should GPS go out of service. GPS is a great idea, and we can indeed save money by decommissioning some ground-based NAVAIDs... let us just not go overboard and decomission them ALL. -- Richard Kaplan, CFII www.flyimc.com |
#44
"Roy Smith" wrote in message ... old-style push mower. But let's be serious; it's absurd to talk about Loran being a reasonable or economically practical anything. Used Lorans are dirt cheap by aviation standards -- often under $300 for used yellow-tagged equipment. Adding a Loran at the time of a GPS installation and removal of VORs etc. would not be a big deal. Even better, Loran would be the ideal backup to be included in a hybrid GPS-Loran box which would switch to Loran if/when GPS went out of service. I mention Loran because for a very low price it could in an emergency continue to provide navigation to every airport and airway -- none of the alternate systems could do so at nearly the same cost. But if selected VORs were instead retained as a backup because all IFR planes now have a VOR receiver, then sure, that is fine too.. that point is to have some backup, whatever that may be. -- Richard Kaplan, CFII www.flyimc.com |
#45
Stan Gosnell writes:
There is no redundancy now. What happens if the weather is 200 ovc & the localizer goes out? All it takes is one power failure, or one transmitter to go south, & you're SOL. With GPS, there are multiple satellites, and you aren't tied to one transmitter like you are with ILS. You have already planned for a redundant destination -- the alternate -- with its own transmitter (or possibly VMC), and you've ensured that you have sufficient fuel on board to get there. All the best, David -- David Megginson, , http://www.megginson.com/ |
#46
In article , "Ron
Natalie" wrote: look at what happened with FM stations just below the ILS frequencies. They're still there. What are you referring to? As far as I know the FM broadcast band has been intact for a long time. There are even some low power stuff that shows up down below 88.1. One of the biggest stations in the area is still on 107.7. ok, I see where I wasn't clear. Countries have allowed FM stations to increase their transmitted power. This has the effect of bleeding into the lower ILS frequencies. As a result, some ILS receivers have to be modified to protect the signal from interference. If you are truly bored sometime, more information can be found by searching on the phrase "protected ILS" -- Bob Noel |
#47
I'm not sure what you mean "Tying the GPS to your altimeter (as is possible
with the CNX-80)" Most GPSs will accept altimetry data to substitute for a fourth satellite. I have a Shadin ADC 2000 providing this data to my 530/430 combo and I have never had a RAIM warning.since I had the 430 and ADC 2000 installed in 1999. Mike MU-2 "C J Campbell" wrote in message ... "Richard Kaplan" wrote in message news
|| | "Scott Moore" wrote in message | ... | | There are multiple GPS satellites making up the GPS system. That is the | exact same redundancy. | | And it is not sufficient redundancy... it can be jammed locally and leave | the pilot with no navigation alternative. | | The very fact that we have RAIM alerts shows exactly why GPS cannot be the | only remaining navigation system -- if all we have is GPS, what do we do | when we get a RAIM alert? WAAS is offering approaches where there are none now, so the GPS is giving me an option where none existed before. A RAIM alert does not disable your GPS; it only means that you cannot fly an approach with it. It is still good for terminal and en route operations. Unless you have a bad installation you should not get RAIM alerts very often anyway -- at least no more often than, say, having the localizer inoperative at an airport. In fact, I have never had a RAIM alert since I installed IFR GPS in my planes, but I have flown to numerous airports where the localizer and/or glideslope was inop during that time. Tying the GPS to your altimeter (as is possible with the CNX-80) reduces the required satellites for RAIM by one, making RAIM alerts even less frequent. If all you have is GPS and you get a RAIM alert, you do the same thing you would if you arrived at an airport and found the only navaid used for approaches there is out: you fly to an alternate. |
#48
Richard Kaplan wrote:
When I bought a new clock for my airplane last year, the cheapest I could find was $78 for analog or $400 for digital. The extra money is to make it terrorist proof. -- For most men, true happiness can only be achieved with a woman. Also for most men, true happiness can only be achieved without a woman. Sharp minds have noted that these two rules tend to conflict..... |
#49
"Scott Moore" wrote in message ... Fine, you have a study. What we need is an unbiased comparision of the vulnerabilities of GPS to the vunerabilities of VOR. That is all No, we need an unbiased comparison of the vulnerabilities of a world with only GPS and ASR vs. a world with GPS, ASR, VOR, NDB, ILS, Loran, LOC, SDF, LDA, and DME. -- Richard Kaplan, CFII www.flyimc.com I hear the terrorists are going to be placing a big magnet in the middle east soon, and mess up everyones compass. Say, lets bring four course ranges back, those were pretty terrorist proof. -- For most men, true happiness can only be achieved with a woman. Also for most men, true happiness can only be achieved without a woman. Sharp minds have noted that these two rules tend to conflict..... |
#50
"Roy Smith" wrote in message ... old-style push mower. But let's be serious; it's absurd to talk about Loran being a reasonable or economically practical anything. Used Lorans are dirt cheap by aviation standards -- often under $300 for used yellow-tagged equipment. More like free. Just look in the dumpster behind any avionics shop. -- For most men, true happiness can only be achieved with a woman. Also for most men, true happiness can only be achieved without a woman. Sharp minds have noted that these two rules tend to conflict..... |
| Thread Tools | |
| Display Modes | |
| Engine update, good and bad news | nauga | Home Built | 3 | June 25th 04 07:26 PM |
| Sport Pilot Leaves DOT for OMB, Latest News | Fitzair4 | Home Built | 3 | December 25th 03 03:49 AM |
| Test..sorry, please ignore, just trying a new isp, news server, and newsreader. | Doug Sowder | Aerobatics | 0 | November 9th 03 07:04 PM |
| It's all about the credibility you don't have, ChuckZZZ | Juan.Jimenez | Home Built | 8 | November 4th 03 02:03 PM |
| News server problems on just this group | Chris W | Home Built | 9 | August 9th 03 03:32 AM |
