AUTOPILOT PROS & CONS
Old May 5th 06, 04:58 AM posted to rec.aviation.ifr
Default AUTOPILOT PROS & CONS
I got my IFR rating 7 months ago. I use the KAP140 autopilot a lot. From
climb-out to MDA/DA. I find it really helps in my management of the plane
and the IFR flight. I am interested in comments regarding the pros and cons
of a heavy use/reliance on the autopilot.
Old May 5th 06, 05:15 AM posted to rec.aviation.ifr
I never use it. I don't feel like I'm flying if I don't have my hand on
the yoke. I don't fly IFR enough that I want to risk losing the
proficiency I have, and although it has been said that one is safer with
the autopilot on, I believe one =becomes= less safe relying on it.
Jose
The price of freedom is... well... freedom.
Old May 14th 06, 07:01 AM posted to rec.aviation.ifr
I never use it. I don't feel like I'm flying if I don't have my hand on the yoke.
We have guys like that in CAP (most are 30 years older than me). The
problem is that those pilots cannot transition to the new G1000
aircraft because there is just no way to hand fly the plane, look for
traffic and exercise all the complex stuff the G1000 glass cockpit
provides. You really have to step back and manage the aircraft rather
than fly it. You need to know what the plane is doing and what it will
do next. The guys who are hand flying it are just keeping up and not
able to determine what the plane should do next. Of course the plane
can be flown just fine w/o the autopilot but passing the check ride
requires you to demonstrate using the G1000 features while airborne.
-Robert, CFI (G1000 instructor)
Old May 15th 06, 08:19 PM posted to rec.aviation.ifr
I agree with everything you say, yet I wonder whether a single pilot can
effectively manage it all with an autopilot and also keep a good lookout
for traffic.
Old May 5th 06, 05:48 AM posted to rec.aviation.ifr
An autopilot is very useful as long as it is used properly.
In VMC, use the autopilot to fly the departure, allowing you
more time to scan for traffic. This is very important in
night VMC. Use the autopilot at cruise to let you rest and
while checking on weather. Use the autopilot for some of
your approaches so you are proficient in the management of
the system. But hand fly enough so you are 100% proficient
because the autopilot can fail.
If you had a live copilot, you would share legs, treat the
A/P the same, use it as an aid not a crutch. Be sure to
read the entire POH supplement and know all the limitations
and failure modes.
James H. Macklin
ATP,CFI,A&P
some support
"STICKMONKE" wrote in message
the pros and cons
Old May 5th 06, 10:13 AM posted to rec.aviation.ifr
Stickmonke,
As one data point: In Germany, single pilot IFR flying requires the
aircraft to have at least a two-axis autopilot (that is, including
altitude hold).
Thomas Borchert (EDDH)
Old May 5th 06, 01:17 PM posted to rec.aviation.ifr
altitude hold).
But is the pilot required to use it? :-)
Bob Noel
Looking for a sig the
lawyers will hate
Old May 5th 06, 01:39 PM posted to rec.aviation.ifr
Bob,
Well, if you don't, "ve haf wais off makink yu!" ;-)
Old May 5th 06, 10:35 AM posted to rec.aviation.ifr
I have always used an autopilot if it's available for cruise flight only. I
hand fly all climb outs and approaches. As a matter of fact, since nothing I
have access to these days has an autopilot, I hand fly the entire flight. G
Mortimer Schnerd, RN
VE
Old May 5th 06, 01:52 PM posted to rec.aviation.ifr
"Mortimer Schnerd, RN" wrote in message
cons
I hand fly all climb outs and approaches. As a matter of fact, since
nothing I have access to these days has an autopilot, I hand fly the
entire flight. G
Cessna and most other "heavy metal" manufacturers, as well as such
publications as "Professional Pilot" recommend use of the autopilot
immediately after takeoff to enhance scanning for traffic. Since the
overwhelming majority of mid-air's occur in the airport area and during
climb out and descent, that makes good sense.
Experimental Catagory: Pros and Cons? [email protected] Soaring 18 April 16th 06 10:56 PM
Long Tow Rope Pros & Cons chris Soaring 7 December 10th 03 02:30 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
