#11
Bending graphlite rod
wrote Perhaps more to the point, I just suggested a rib as an example. Being able to bend graphlite rod like one steam bends wood opens up a lot of design possibilites. Imagine, instead of reinforcing other materials with the rod, making a wing, or wing and fuselage built like a birdcage and then covered with Dacron. Not the cheapest and maybe not the lightest or strongest and certainly not the most practical way to go. But an interesting concept. How about using flat graphite stock and laminate the shape you want to end up wit. That would eliminate purdy much all of the preload, no? g -- Jim in NC |
Morgans wrote: wrote Perhaps more to the point, I just suggested a rib as an example. Being able to bend graphlite rod like one steam bends wood opens up a lot of design possibilites. Imagine, instead of reinforcing other materials with the rod, making a wing, or wing and fuselage built like a birdcage and then covered with Dacron. Not the cheapest and maybe not the lightest or strongest and certainly not the most practical way to go. But an interesting concept. How about using flat graphite stock and laminate the shape you want to end up wit. That would eliminate purdy much all of the preload, no? g The cat's meow would be pultruding it directly into the desired shape. That's a bit beyond the capabilites of the homebuilder--I think. -- FF |
Ernest Christley wrote: wrote: Perhaps more to the point, I just suggested a rib as an example. Being able to bend graphlite rod like one steam bends wood opens up a lot of design possibilites. I think you're missing the forest for the trees. A wood steamer is your answer. Make a form out of sheet metal, then bend the graphlite around it. Tg is around 180F for most epoxies, so an hour at 212F should turn it to it's plastic state throughout. The internal bending stresses will pull themselves out. Take it out of the oven, and it should hold whatever shape it had been forced into. I first tried heating the rod in boiling water and bending it. No dice. I then tried heating it with a heat gun, still wouldn't bend. But that time I heated the middle of the rod, not the end. I'll go back and try heating the end. Then I may take up your suggestion, but bending the rod to a tight curve while it is at room temperature is NOT trivial. Phenolic resins are thermosetting. While they do have a glass transition temperature, that GTT increases when the material is heated, making it a moving target. My impression is that most phenolic resins will char befor they soften. There are thermoplastic resins that have a reproducible GTT. Dunno if anybody makes pultruded rod using them though. I am also less than confident in the vendor's published descriptions of the products. Even if they were accurate when written the vendor may change their source to a similar product without updating the description. Now, what I understand of graphlite is that it gets it's strength from having all the fibers aligned and equally tensioned. Doing the above, you will probably get something only marginally better than a hand layup. But you won't know until you try. You and a preceding author both raised this point and it is well taken. Maybe if the rod is bent 'monotonically', I.e. bent onto the form without wiggling it the fibers will slip in only one direction and retain their approximately equal tension. -- FF |
"Ernest Christley" wrote in message
... I think you're missing the forest for the trees. A wood steamer is your answer. Make a form out of sheet metal, then bend the graphlite around it. Tg is around 180F for most epoxies, so an hour at 212F should turn it to it's plastic state throughout. The internal bending stresses will pull themselves out. Take it out of the oven, and it should hold whatever shape it had been forced into. Now, what I understand of graphlite is that it gets it's strength from having all the fibers aligned and equally tensioned. Doing the above, you will probably get something only marginally better than a hand layup. But you won't know until you try. You are making some assumptions that are incorrect. First, movement of the fibers inside a resin system heated to Tg degrades the mechanical properties of the mass after it cools. This is because Tg is a temperature point that is usually used to define destruction of the member due to it's inability to maintain designed mechanical properties. In your description, epoxy is a thermoplastic that can be heated/formed and cooled repeatedly without loss of properties. In reality it is a thermoset and is not remoldable. The loss of mech properties happens as a microshear failure inside the matrix as the resin and fiber move relative to each other "crumbling" the crystaline structure of the resin. Be very careful when suggesting that heating a laminate to Tg, bending it, allowing it to cool is an answer to "reshaping" the part without serious degradation of the properties of the resin. OBTW, Graphlite is a BIS F Epoxy with a Tg of 100C. |
Similar Threads | ||||
Bending sheet stock | Michael Horowitz | Restoration | 1 | April 24th 06 04:28 AM |
Wing Bending Oscillation | jcarlyle | Soaring | 18 | February 21st 06 04:37 PM |
Bending extruded angle | Veeduber | Home Built | 8 | August 29th 04 12:58 AM |
Building the Po' Boy Bending Brake | Veeduber | Home Built | 14 | March 1st 04 06:15 PM |
Minimum bending radius for 0.050" 6061-T6? | Bob Chilcoat | Home Built | 11 | February 5th 04 04:59 PM |
