Hydraulic brake problems
On Mar 27, 9:34*am, Dick wrote:
Hydraulic brake problems. *The disc brake on my D2b has provided only very limited stopping ability for a year or so now. *When attempting to put on the brakes the brake handle moves all the way back to the stick grip. *We have repeatedly attempted to eliminate air in the system by pumping .4 fluid up through the wheel cylinder drain nipple. *We have sucked the system dry by vacuum applied, also to the same nipple. *We have checked the nipple itself for blockage. *We replaced the master cylinder. *We checked the cable to make sure there was no slack yet the abbreviated handle plunger was virtually in contact with the piston in the master cylinder and the master cylinder piston was moving. *Nothing seems to make any difference. *IT Sounds like you are doing everything right. I assume you checked for wear of the pads? Easy to replace them and always a good idea. Also it is easy to replace the O-ring on the brake master cylinder. However you would see seepage atounf the Master cylinder if it is bad. I change them every few years because they do get old and hard. good luck, Dan WO |
Similar Threads | ||||
Bleeding LS4 wheel brake hydraulic system | David Starer[_3_] | Soaring | 1 | April 3rd 10 04:06 PM |
hydraulic brake actuation | Brad[_2_] | Soaring | 15 | January 9th 09 05:46 AM |
Hydraulic trailer surge brakes means no parking brake? | [email protected] | Soaring | 11 | March 18th 08 04:19 AM |
Hydraulic Pump | [email protected] | General Aviation | 2 | March 28th 06 05:09 AM |
AP: Navy Jet Has Severe Brake Problems | Otis Willie | Naval Aviation | 0 | August 6th 05 12:20 AM |
