Bleeding LS4 wheel brake hydraulic system
Old April 3rd 10, 09:27 AM posted to rec.aviation.soaring
David Starer[_3_]
Default Bleeding LS4 wheel brake hydraulic system
Does anyone have any experience of bleeding the hydraulic system that
activates the LS4's wheel brake? I have heard a suggestion that it is
necessary to unbolt the master cylinder and hold it in a vertical position
in order to expel all the air from the system. Is this really true?
Also, does anyone know whether any particular type of brake fluid is
recommended or would something off the shelf be OK?
Any hints or tips would be really helpful.
Many thanks.
David Starer
Old April 3rd 10, 05:06 PM posted to rec.aviation.soaring
Grider Pirate
Many thanks.
David Starer
LS4 Hydraulic? Just cables on ours. If it's a modification - all bets
are off. Caution he if it's made to use Aircraft brake fluid (Mil
5606), putting automotive Dot 3 or Dot 4 in it will turn the seals to
goop. If it's made to use automotive Dot 3 or Dot 4, putting 5606 in
it will ruin it quickly. Easy to tell them apart. 5606 is very red
and has a strong odor which is nothing like automotive.
The other option is to competely purge and clean the brake hydraulic
system and run DOT 5 silicone based automotive brake fluid.
brake bleeding Pintlar Home Built 15 April 7th 10 04:01 AM
bleeding brake help Pintlar Home Built 8 November 7th 09 01:41 PM
hydraulic brake actuation Brad[_2_] Soaring 15 January 9th 09 06:46 AM
Hydraulic trailer surge brakes means no parking brake? [email protected] Soaring 11 March 18th 08 05:19 AM
SZD-55 Wheel Brake David Pye[_2_] Soaring 0 September 18th 07 07:01 PM
