AOA indicator poll.
Cool, I did a cal flight in that area this weekend.
Made a new flap setting ring for the ASI. Added an inside piece of tape for the outside pitch string. In flight, added a dot to mark string position for best L/D. Then checked to see if the center of each flap settings on the ring matched the dot. They did pretty well. I've been thinking about an electronic AOA for sensing the H&V air direction. I have an Ardinuo and diff transducer rigged to a machined nose piece with a pitot and angled port. It can sense a 1% angle change on the bench with a wind tunnel (some call it a shop vac). But I'm not sure if it would be any better than normal instruments already there. Your picture shows you also have the pitch string. Have you added the dot and checked to see if the electronics stay's green at different speeds but still on the dot? |
Similar Threads | ||||
AOA indicator | Jonathan St. Cloud | Soaring | 116 | May 2nd 16 05:53 PM |
Need VOR indicator | blanche cohen | Owning | 5 | July 23rd 07 04:37 AM |
Need VOR indicator | blanche cohen | Instrument Flight Rules | 5 | July 23rd 07 04:37 AM |
Which Indicator for KLN-89b | N7936T | Instrument Flight Rules | 3 | June 1st 06 06:50 PM |
Non TSO'd IFR indicator | Paul Lee | Home Built | 1 | September 19th 03 07:00 PM |
