Need VOR indicator
Old July 9th 07, 10:29 PM posted to rec.aviation.ifr,rec.aviation.owning
blanche cohen
Default Need VOR indicator
For those of you upgrading and have excess equipment....
my VOR/GS/LOC indicator died and I'm looking for one of the following:
GI 106A
KI 209
ND 200-306
It's got to talk to an SL30.
Remove the Dark Matter (the blackhole) to respond by email. Or
just post here, that's good too.
thanks
Old July 18th 07, 03:51 PM posted to rec.aviation.ifr,rec.aviation.owning
Blanche
Blanche wrote:
GI 106A
KI 209
ND 200-306
Is this the same indicator you wrote about that would not give the
right/left indications on the ILS?
Yup. After extensive talks with Salem, OR (home of Apollo...er...GarminAT)
the consensus is that the MC60 doesn't play well with too many
NAV/COM. So I'm going to move the MC60 to play with the TKM MX12 (which
means it *better* play well, since it's the same company) and
get one of the three above. According to the folks in Salem, they've
only tested it with these three and a Collins unit.
And after playing with everything again, I've discovered two interesting
facts. One is documented in the SL30 user guide (and it never sunk it,
but then, I never needed it): when
on backcourse, the VOR indicator is dark, which makes sense,
since it would be very confusing to have 2 indicators going
in opposite directions.
The second, which I cannot find anything related in the manual:
I've discovered what appears to be to problem/solution to not
seeing the LOC on approach. I've had the 2nd NAV freq (the
one on standby) selected to monitor the freq. This turns the
LOC off, yet keeps the GS active on the VOR indicator.
so - the SL30 *does* play well with the MC60 afterall. I just
need to remember to NOT turn on "monitor 2nd NAV" while on
approach. I've sent a note to Garmin/AT to ask if this is normal
or did something get wired wrong.
Old July 18th 07, 04:11 PM posted to rec.aviation.ifr,rec.aviation.owning
El Maximo
"Blanche" wrote in message
WOW!
A zero AMU radio fix!
Old July 23rd 07, 05:37 AM posted to rec.aviation.ifr,rec.aviation.owning
Jim Macklin
Strange how many pilots never really study their AFM and all
the supplements.
That is why those silly PTS require applicants to
demonstrate the proper use of all the equipment installed.
equipment....
of the following:
| GI 106A
| KI 209
| ND 200-306
not give the
many
TKM MX12 (which
and
Salem, they've
two interesting
never sunk it,
sense,
going
manual:
not
just
normal
TKM MC-60 indicator install Dave Reinhart Owning 2 March 3rd 07 05:56 PM
TKM MC-60 Indicator installation Dave Reinhart Owning 1 February 26th 07 03:11 PM
Which Indicator for KLN-89b N7936T Instrument Flight Rules 3 June 1st 06 07:50 PM
KI-209 VOR/LOC/GS Indicator adjustment kontiki Owning 13 April 26th 05 12:35 AM
WTB: ARC 300 ADF Indicator Ben Smith Aviation Marketplace 0 August 30th 04 10:19 PM
