Tolerances - Published Minimum Altitudes
If assigned IFR altitudes can be considered to have a tolerance of +/-
200 ft before you are "busted", what applies to published minimum altitudes other than DH and MDA on approach plates? Most people will say that you are not supposed to descend any amount below the DH/MDA altitudes. Does this also apply to procedure turn altitudes, transitions etc.? Is there a tolerance that is in effect +200 -0 that applies? In practical terms, whereas a decent of 100 ft below an assigned altitude will cause no problems, is such a decent of 50-100' below a published procedure turn altitude, transition altitude enough to get in trouble? John |
Similar Threads | ||||
FAA regs. for minimum altitudes over built-up areas | PPL-A (Canada) | Piloting | 16 | October 16th 06 09:11 PM |
Odd VSI behavior at higher altitudes | Nathan Young | Owning | 4 | August 2nd 05 10:38 PM |
Picking Optimal Altitudes | O. Sami Saydjari | Instrument Flight Rules | 20 | January 8th 04 02:59 PM |
Ta-152H at low altitudes | N-6 | Military Aviation | 16 | October 13th 03 03:52 AM |
Tolerances and fit. | Roger Halstead | Home Built | 4 | September 14th 03 03:14 PM |
