KY-97A sidetone adjust
Someone was mentioning that the sidetone might be externally adjustable
after pulling radios out of the tray. The sidetone on my 97A has always been low compared to my SL30. Does anyone know specifically how to adjust the sidetone for this radio? I pulled it out of the tray and the only candidate I noticed was an unlabeled white nylon screw on the bottom of the radio. There is also a small round opening in the front plate on the left with what looks like blue plastic behind it. It is also unlabeled. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel Politics is the art of looking for trouble, finding it everywhere, diagnosing it incorrectly, and applying the wrong remedies. |
Mike Noel wrote:
I pulled it out of the tray and the only candidate I noticed was an unlabeled white nylon screw on the bottom of the radio. There is also a small round opening in the front plate on the left with what looks like blue plastic behind it. It is also unlabeled. There are two small holes in the front of the Ky-97A. One (which you already know) is used to unlock the unit from the tray. The other is a light sensor for the dimmer circuit. Do not stick anything in there. It's very sensitive and easily damaged. Can't help you on the sidetone adjustment. John Galban=====N4BQ (PA28-180) -- Message posted via http://www.aviationkb.com |
Similar Threads | ||||
question about radio sidetone | Gary R. | Owning | 3 | April 10th 07 07:03 AM |
Calibrate? Repair? Adjust? | RST Engineering | General Aviation | 3 | April 4th 05 01:41 PM |
Radio sidetone problem | Marty from Florida | Owning | 4 | April 2nd 05 09:36 PM |
TKM MX-11 Sidetone | Rohit Fedane | Owning | 0 | January 22nd 04 04:59 AM |
TKM Michel MX-170B Sidetone | Mike | Owning | 0 | December 30th 03 12:44 PM |
