A recent thread on what a person with an FCC license would have to do to
install/calibrate/repair/adjust radios led me to do the research that I generally wind up doing once a year when this thread comes around again. Let's talk about the plain old airframe mechanic ("AM") and the feller with the FCC radiotelephone certificate ("FC"). Part 43 of the regulations specifically state that there are two categories of "calibration" that are major repairs -- "calibration of and repair of instruments. Calibration of radio equipment." Note that Part 43 cleverly left OFF repair of radio equipment, while it retained it on instruments. The FAA ain't dumb; they've got a stable of lawyers writing this stuff. If they had MEANT to include repair of radio equipment under major repair, they would have done so. They did not. So let's go to Part 65 to see what AMs *are* allowed to do. 65.81a allows a AM to "perform maintenance ... on appliances ... except ... repair to instruments." Note again the clever mention of instruments and the non-mention of radio equipment. So we see that AMs with the requisite experience (again, "...the AM ... may not perform the maintenance or repair ... unless he [sic] ... has performed that maintenance at a prior time ...") may, in fact, repair radios. They just can't CALIBRATE them when they are completed with the repair. Since 14 CFR Part 1 does not define "calibrate", we have to turn to another authority. In general, the courts have held that in the absence of a specific definition of the controlling authority, or a generally accepted practice in the industry, a recognized dictionary definition may be used. Webster says that calibration is " ... to correct the graduations of a measuring instrument (as in a thermometer). Is "alignment" calibration? Not by this definition. Is "adjustment" calibration? No. So let's turn our heads from radio repair to "instruments". What is an instrument? Clearly, airspeed, gyroscopic indicators, pressure, temperature, and those sorts of things are instruments. Indeed, Webster comes to our help once more with a definition of instrument as "...a tool or implement, especially one used for delicate work or for scientific or artistic purposes." This is a particularly lousy definition for an aircraft instrument, but let's build on it. The specific question is whether or not a VOR head is an "instrument" in light of the above. I can argue both ways and make good argument that it is either a "radio" or an "instrument" depending on how we view it. So, can I legally repair a VOR head? I argue that this is a truly gray area open to MUCH interpretation and argument and I can sit on either side of the table with some degree of comfort. Now, during an install, a radio needs a couple of adjustments. Sidetone and modulation level come to mind quickly. Since AMs can repair and align, saying that they can't touch the installation controls is an absurdity. However, adjustment of the modulation level CAN cause distortion and splatter, so in this ONE ISOLATED case, I can argue for the need of a FC certificate to make the adjustment. Otherwise, it is a pretty piece of paper to hang on the wall. Draw your own conclusions. It is your certificate on the line, and I'm not going to argue with your interpretation. Nor am I going to argue with your FSDO's interpretation. Interpretations are just like assholes, everybody has one and most of them stink. Jim Weir A&P, IA FCC 1st phone since 1959 (yes, that means I got it at 16) |
RST Engineering wrote: Jim Weir A&P, IA FCC 1st phone since 1959 (yes, that means I got it at 16) man, had not heard the term "first phone" (s/b fone) in a very long time. got mine at age 18, 1965, and it was my ticket to radio stardom reading hog and corn prices and "music to milk by" at a 250 watt peanut whistle day-timer. yes, the antenna dummy load was a light bulb. "thump that biggun in the back...looks a litle gassy..." reading base-currents in a blizzard on a 5 tower array. always thought it was a come-down when they replaced 'first class' with "general". but i digress....sorry, dan |
houstondan wrote:
always thought it was a come-down when they replaced 'first class' with "general". Me too... I never did renew my ticket after that. |
A recent thread on what a person with an FCC license would have to do to install/calibrate/repair/adjust radios led me to do the research that I generally wind up doing once a year when this thread comes around again. I still consider the entire radio to be connected to be part of the landing light circuit :-) |
| Thread Tools | |
| Display Modes | |
| De-ice boot repair | gbessert | Owning | 3 | August 29th 17 08:30 PM |
| Advised on FAA Repair Station outside USA | tbm700 | Owning | 0 | September 23rd 04 06:50 PM |
| Cirrus canopy frame repair | Louw Pieters | Soaring | 0 | May 29th 04 07:09 AM |
| Canopy crack repair | Pete Brown | Soaring | 0 | May 18th 04 04:09 AM |
| Terra Switch repair | George A. Graham | Home Built | 1 | October 25th 03 01:15 AM |
