Why is ADF required for KSAC ILS Rwy 2 SIAP?
Old May 2nd 06, 10:40 PM posted to rec.aviation.ifr
Default Why is ADF required for KSAC ILS Rwy 2 SIAP?
There's a NOTAM out for KSAC ILS-2 which states that the following
note should be added to the planview: "ADF Required".
Why is ADF required for this IAP? The marker beacon should tell you
when you're over the LOM, and the missed approach procedure says you
need to hold at the VOR or the NDB.
Is there some requirement for the use of the ADF which I'm not seeing?
Thanks,
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old May 3rd 06, 01:14 AM posted to rec.aviation.ifr
"Mark Hansen" wrote in message
There are two current NOTAMs for SAC. The one you mentioned, and one
showing the VOR unserviceable. Without the VOR an ADF is needed for the
missed approach.
Old May 3rd 06, 02:57 AM posted to rec.aviation.ifr
missed approach.
Thanks Stephen.
The VOR being OTS is temporary. It will be out from 9:00AM to 4:00PM
on Wednesday (local time).
I was under the impression that the change to the SIAP was permanent...
Because it was done via an FDC NOTAM. Perhaps I'm off base there?
They said it was AMDT 22C.
So will they then come out with an AMDT 22D which says to remove
the note?
I just didn't think they would make a permanent change (FDC) to the
SAIP for a temporary condition.
Sacramento, CA
Old May 3rd 06, 03:12 AM posted to rec.aviation.ifr
The NOTAM says "WIE UNTIL UFN", With Immediate Effect Until Further Notice.
It may not be pernanent.
the note?
Once you've spent a few years reading these things you stop trying to find
any logic in them. The VOR outage justifies the amendment to the IAP, but
it's possible they're unrelated.
Old May 3rd 06, 02:19 PM posted to rec.aviation.ifr
Thanks,
ADF is required for the transition from COUPS.
Old May 3rd 06, 02:22 PM posted to rec.aviation.ifr
missed approach.
Thanks Stephen.
the note?
They don't issue Permanent FDC NOTAMS (which is what one is when it
amends the procedure from 22B to 22C). They will sometimes issue a
temporary FDC NOTAM for a facility outage, but never for one day.
These NOTAMS are geared to NACO charts. NACO cannot chart a T FDC
NOTAM. They must chart a P FDC NOTAM.
Old May 3rd 06, 02:27 PM posted to rec.aviation.ifr
missed approach.
Thanks Stephen.
Oh ... rats. I meant "Steven", of course. Sorry about that.
Sacramento, CA
Old May 3rd 06, 02:40 PM posted to rec.aviation.ifr
Thanks,
That's interesting. In all the times I've flown that in training, I
think we've always just used the localizer. However, in looking at
the chart now, the feeder route says "1400 NoPT 015 TO LOM".
However, if you're coming in from COUPS, wouldn't you be on the
localizer before you get to the LOM? After all, by this point,
you're already on the GS. Why would anyone fly the ADF to the
LOM on this approach?
Also, what changed such that the ADF is required now, and wasn't
before? Was it always required, but the chart just didn't say so,
and they are now correcting that?
Thanks,
Sacramento, CA
Old May 3rd 06, 04:02 PM posted to rec.aviation.ifr
Thanks,
Thanks,
There is a lot of subjectivity in procedure design. According to my
source, and I quote:
"This is one of those old ILS procedures done by some of our old
pilot/developers years ago. The in NoPT route goes to the LOM, one
reason for ADF required, and the procedure was generating too many
questions. We have it on the list to fix."
Old May 3rd 06, 06:03 PM posted to rec.aviation.ifr
"Sam Spade" wrote in message
news:G526g.175119$bm6.2264@fed1read04...
No it isn't, COUPS is on the SAC 195 radial.
tailwheel endorsement Jose Piloting 65 April 27th 06 01:59 AM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
