Region 9 Parowan update # 3
We have received applications and deposits from the following contest
ids, they are NOT, repeat, NOT in any order. YC, UE, XS, HL, 711, 7E, VH, MI, SD, XI, BF, QF, QT, 4S, MR, L33, A8, MM, AP, IY, CI, 888, 21, AS, GW, SSB, JP, P7, CH, V0, 98, 4Z, IV, RX, BV, MG, F2, 2NO, GO, 7U, 7V, 44, JJ, OD2, HAL, UI, XPT, TO, BG, 1X. Also, Sylvia Szararczyk, who is getting a contest id. Due to new Dell laptop kabooming, pilot entry list will be updated on webpage around Feb. 8th. We will have remote wireless available in hanger for everyone's needs. Weather outlook for soaring contest, which is long range, can change, but might not, is 18 thousand foot bases of hard white bottom cues, lift indexs 10-15 kts, gently breezes giving way to long cloudstreets, endless running without turning, causing hanger parties to the wee hours from all the smiles and giggles..........sure hope it stops snowing soon in Alamogordo, I need to get out and take a walk............. Thermal tight, Soar high, Fly safe, # 711 reporting. |
Tommy
If that weather forecast comes true, you can be the weatherman for every contest in the country!!!! Kellerman is shaking in his boots!!!!!! Brian Glick wrote in message oups.com... We have received applications and deposits from the following contest ids, they are NOT, repeat, NOT in any order. YC, UE, XS, HL, 711, 7E, VH, MI, SD, XI, BF, QF, QT, 4S, MR, L33, A8, MM, AP, IY, CI, 888, 21, AS, GW, SSB, JP, P7, CH, V0, 98, 4Z, IV, RX, BV, MG, F2, 2NO, GO, 7U, 7V, 44, JJ, OD2, HAL, UI, XPT, TO, BG, 1X. Also, Sylvia Szararczyk, who is getting a contest id. Due to new Dell laptop kabooming, pilot entry list will be updated on webpage around Feb. 8th. We will have remote wireless available in hanger for everyone's needs. Weather outlook for soaring contest, which is long range, can change, but might not, is 18 thousand foot bases of hard white bottom cues, lift indexs 10-15 kts, gently breezes giving way to long cloudstreets, endless running without turning, causing hanger parties to the wee hours from all the smiles and giggles..........sure hope it stops snowing soon in Alamogordo, I need to get out and take a walk............. Thermal tight, Soar high, Fly safe, # 711 reporting. |
Similar Threads | ||||
Region 9 Parowan Update #2. | [email protected] | Soaring | 2 | January 19th 07 12:40 AM |
Region 9 Parowan | [email protected] | Soaring | 1 | January 12th 07 06:35 AM |
Tiedowns at Parowan during Region 9 | Kirk Stant | Soaring | 3 | May 12th 04 07:14 PM |
Ground crew services offered - Parowan Region 9 Championships 2004 | Ted Wagner | Soaring | 0 | February 17th 04 07:25 PM |
Region 9 - Parowan Utah | Dirk Elber | Soaring | 0 | February 9th 04 12:54 AM |
