#51
Navigation flight planning during training
Recently, Andrew Sarangan posted:
As I mentioned in a related post, I once had a student who painstaking did all the calculations by hand, but everything was reversed by 180- degrees. It was because he was so caught up with measuring the chart and operating the E6B that he missed the big picture. Isn't "the big picture" in this case learning how to navigate? Is not checking your results and becoming aware that something is wrong is a part of that process? One could argue that had he done it by computer, his brain might have been more relaxted to catch that sort of mistakes. Or, more likely, the computer would have provided a solution that the student would have accepted as unquestionably as the result that was 180º off. That the computer may have given a correct answer is not really evidence that the student has learned anything. Watch a cashier insist that the change for your purchase *should* be more than the cost of the item, and you'll know what I mean. ;-) regards, Neil |
#52
On 2007-03-14 17:45:14 -0700, "John Galban" said:
By the way, when I took my PPL check ride back in the dark ages, I was expected to do more than just give the examiner a WAG on the diversion. I had to turn towards the alternate using a WAG, then come up with the actual course, distance and time to the new airport. In a real life weather diversion, given the possibility of reduced visibility or low ceilings, the accuracy of that calculation could mean the difference between arriving, or flying past the alternate. John Galban=====N4BQ (PA28-180) The check ride hasn't changed since you took it (at least in that respect). The method of coming up with the actual course, distance and time might have change, though. We no longer use leagues for distance, for example. :-) -- Waddling Eagle World Famous Flight Instructor |
#53
One additional comment I would like to add is that, we should not
equate computer usage with lack of understanding of the basics. True, but it is possible (easy in fact) to use the computer without the slightest understanding of what it is doing. It is less possible to successfully plan a flight with pencil and paper and no understanding. where they compared students who learned to fly in glass cockpitsat Embry Riddle vs the traditional instruments The methodology of the study and exactly what is being measured is important to interpret the results. btw, I have almost a thousand hours and still fill in the little boxes by hand. Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
Similar Threads | ||||
Flight Planning PYM to DEN | William Snow | Piloting | 22 | December 12th 05 04:24 PM |
Planning a flight | Chris | Instrument Flight Rules | 23 | February 23rd 05 09:15 PM |
Pre-flight planning really is worth doing. | Roy Smith | Instrument Flight Rules | 6 | August 25th 04 10:17 PM |
Flight planning at the lower flight levels | Peter R. | Piloting | 2 | March 16th 04 02:39 AM |
Flight Planning Software | Joe Allbritten | Piloting | 2 | December 21st 03 02:29 PM |
