This question is directed at student pilots and flight instructors.
How many of you learn/teach cross country navigation using the traditional methods using paper charts, protractors, E6B and navigation logs? During my training more than 10 years ago, xc planning was a fairly elaborate process that involved filling lots of numbers in small boxes. The flight was broken down into approximately 25 mile legs, and each row had distance, true course, winds, temperature, variation, wind correction angle, magnetic heading, time, fuel. Then we add up the columns to get total time and fuel. We also compute the time required to climb and descent. If we want to be more precise, we also compute the fuel needed for taxi and run-up. Once airborne, we religiously write down more numbers at each checkpoint and recompute ground speed. All fine, but I don't do any of these on a typical flight. I use an online source such as skyvector.com to view the charts. Then I use an online software to compute heading and time. That plus a paper chart is pretty much all I need for a VFR flight. I've been toying with the idea of taking a different approach to teaching flight planning by skipping a lot of these things. I don't see the purpose of doing things by hand when it is done much easier on a computer. It feels like using a typewriter instead of a computer. In addition, the less stuff you have in the cockpit, the simpler the organization becomes. All these papers and pens flying around the cockpit becomes an organizational nightmare. So what are your thoughts on this? Is the ability to compute a flight by hand really important? Are there important aspects I am overlooking? |
"Andrew Sarangan" wrote in message
ups.com... This question is directed at student pilots and flight instructors. How many of you learn/teach cross country navigation using the traditional methods using paper charts, protractors, E6B and navigation logs? Snip I'm probably unqualified to offer solid suggestions regarding flight training. But in my limited experience as a pilot, I'll say this: I don't think "analog" flight planning should be overlooked or discounted but any and all tools are, IMO, fair game. The mechanics of doing a flight plan with paper sectional, plotter, flight computer and A/FD make a pilot think about routes, checkpoints, etc... However, use of electronic flight planning tools (and any associated pros and/or cons) should be included in today's flight training environment. In my own personal flying today, I really like the Golden Eagle Flight Prep product as it allows me to play with routes ad infitum (with an eye to terrain avoidance/clearance...the route profile view is really handy) while not turning my sectionals into a spider's web of pencil lines. Once I get the route, I still draw it on my sectional while noting major checkpoints but I also print the "strip maps" of sectional images from Flight Prep and go nuts with pen and highlighter adding freqs, altitudes and circling anything and everything of interest along the way. As for the actual flight plan itself, I find that filing and printing via duats has yielded plans which (so far) I've flown and have yet to be more than +/- two minutes off E.T.E. Letting the "1s" and "0s" do the work should be discussed, used and post-flight scrutinized. Just my $0.02 ... Jay Beckman PP-ASEL Chandler, AZ www.pbase.com/flyingphotog |
Andrew Sarangan wrote:
How many of you learn/teach cross country navigation using the traditional methods using paper charts, protractors, E6B and navigation logs? Yes, yes, yes (analog AND digital), and yes. While I did learn to use the DUATS system for getting briefings, I never file plans with it. I still make the phone call to the local FSS, and I still talk to a real person for a briefing and filing (some of the guys are pretty cool). I still write up the plans by hand, mark them out by hand, compute their relevant stats and highlight POI's, navaids, etc. etc. by hand. I was never taught to use electronic systems (other than the aforementioned information), and I think I'm a better pilot for it. If we want to be more precise, we also compute the fuel needed for taxi and run-up. Once airborne, we religiously write down more numbers at each checkpoint and recompute ground speed. One of the schools that I've flown with before taught us interpolation of EVERY chart and EVERY figure, and how to work in applicable variables (no guesstimating your climb performance if it was +13C above standard, you found the RIGHT number) All wonderful parts of the flying experience (gives you something to do besides watch the GPS, which I've also never been fully versed on; you whippersnappers with your newfangled glass cockpits, it's a Cessna fer Pete's sake!) Checking over your plan keeps your mind focused on the task of navigation, and helps verify and reinforce your capabilities as a pilot and a navigator (which do wonders for confidence), plus it helps you visualize your current situation, and adjust to any new developments by giving you lots of sample points (and keeping your apprised of your current locations with those unburnout-able, unperturbable, invaluable paper charts. I've been toying with the idea of taking a different approach to teaching flight planning by skipping a lot of these things. I don't see the purpose of doing things by hand when it is done much easier on a computer. So what are your thoughts on this? Is the ability to compute a flight by hand really important? Are there important aspects I am overlooking? It is very important to do it by hand; what if things go pear-shaped, and you need to plot a new course NOW, in the air, with only your paper charts, E6B, ruler and a friendly voice at the other end of a NAV/COM? What if your fancy-dancy multi-thousand dollar GPS system goes tits-up? You have an electrical short (or an alternator failure, and need to conserve power)? While the merits of filing through DUATS can't really be argued (especially if your typing skills are up to snuff), flying was, is, and should always be a social experience; there's nothing to replace human contact, even if it's with an FSS jockey, there's an inexorable feeling of knowing that somewhere, at least one real person knows where you're going, to say nothing of the often-times helpful suggestions of places to see or diversions worth making that I've received before. Doing things by hand keeps a pilot intimately acquainted with his craft, with the process and necessity of each step (and how to actually read those prog charts!), with muscle memory and skills that can always be fallen back on in emergency, and helps keep the social traditions of flying alive. TheSmokingGnu |
I believe the basic methods should still be taught to student pilots
and I do teach them. IMHO pilots should be able to flight plan without computers, satellites or high speed internet. Once these skills have been learned and the underlying principles understood then I'm all for using a computer to do it. |
This question is directed at student pilots and flight instructors. How many of you learn/teach cross country navigation using the traditional methods using paper charts, protractors, E6B and navigation logs? Well, I'm neither but I am traditional. Certainly the newer and more convenient ways of flight planning need to be taught. At the same time, I think you're doing your student a disservice if he doesn't learn how to do it the old fashioned way. You don't always have access to a computer. It would be analogous to expecting to fly by GPS only to have it take a crap on you. Certainly being able to find your way via VORs and NDBs would be an advantage. When I was learning, even though we had a perfectly reliable VOR system, we still were expected to be able to find our way by pilotage. I can, too... though it's hardly the way I'd choose to go. But the skill set wasn't a total waste of time. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
nope - mine's a $125 hiker's model. But seriously folks...I find that planning is much more fun than most flying. Let's face it - as a VFR pilot, a cross-country is pretty boring (at least out here in the west, if you avoid the mountains). Not too many people to talk to, we don't have an airport every 5 miles, we're usually too low to talk to Center, etc. I admit, I use software for flight planning - but then, I'm a Professional Geek. As one of the other posters noted, it's so much easier to look at alternates, deal with terrain, etc than marking up the maps. Once I settle on a route, then I may or may not copy it to the physical map. Depends on the route and length of the flight. DEN-PUB? Nope. Got that one pretty well memorized. I left my GPS (I really do have an aviation GPS portable, too) in the trunk of the car this past week (thought I'd lost it!) and was "forced, I mean sir, FORCED" to use maps and VORs. Which I do all the time anyway. Around here, the GPS is invaluable for monitoring where Class B and MOAs are located (and out west, they are growing!) But I don't circle stuff on the maps - I use yellow stickies that I've written pertinent info (wx, freqs, etc) in LARGER letters so I can more rapidly & easily find it. Even wearing the bifocals, that type on sectionals and IFR maps is just too tiny in the cockpit. Of course the freqs & info for the VORs and airports I need are on a half-sheet on the yoke (in 14 pt type) |
On 03/13/07 03:32, Mortimer Schnerd, RN wrote:
Andrew Sarangan wrote: This question is directed at student pilots and flight instructors. How many of you learn/teach cross country navigation using the traditional methods using paper charts, protractors, E6B and navigation logs? Well, I'm neither but I am traditional. Certainly the newer and more convenient ways of flight planning need to be taught. At the same time, I think you're doing your student a disservice if he doesn't learn how to do it the old fashioned way. You don't always have access to a computer. The only thing I would change in this paragraph is calling it "the old fashioned way". I think the student should learn and understand the basics of the flight plan before automation can safely be applied. Learning the basics really drive home the issues of wind correction angles, fuel consumption, etc., all very important concepts even when using automated flight planning software and GPSs. It would be analogous to expecting to fly by GPS only to have it take a crap on you. Certainly being able to find your way via VORs and NDBs would be an advantage. When I was learning, even though we had a perfectly reliable VOR system, we still were expected to be able to find our way by pilotage. I can, too... though it's hardly the way I'd choose to go. But the skill set wasn't a total waste of time. What you should choose depends on the flight. Some flights I navigate by pilotage simply because it is more fun. Especially night flights. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
This question is directed at student pilots and flight instructors. How many of you learn/teach cross country navigation using the traditional methods using paper charts, protractors, E6B and navigation logs? Neither student nor teacher, but I was a student not so long ago (4yrs) and that is how I was taught. With my trusty E6B and just what all those numbers mean. The cool thing about learning how to flight plan that way is that it teaches you all the underlying principles behind navigation. Plus it builds a foundation for going on to advanced ratings. Take something like WCA. How could you do a 1 minute hold if you didn't understand how to calculate wind correction? Likewise for emergency planning, how much fuel do I have, can I make that field? You have to know all the numbers from the POH to do that. So it is good stuff. Lastly it satisfies the FAR 91.103 PIC, BEFORE beginning a flight shall become familiar with all available information concerning the flight. Grabbing a printout from some flight planning service doesn't qualify in my mind. Of course, "familiar" is vague. I'm sure the lawyers on this list will parse that ad nauseum. KC |
Well, that is the question - as we move into the age of instantaneous
position display on the panel... Like you, I learned to plan a flight by practically wearing out an E6B and laying waste to a small forest... Then the flight was made by sweating my way from one check point to another at a flaming 96 mph at 1500 feet agl, in my nordo T-Craft... Does that particular skill mean anything today? - Well, I guess if every electronic navigation aid was shut down I could, push comes to shove, pull out the old E6B and plan a flight from the Canadian border down to Florida, the old way... Actually I'm not looking forward to it, though... The planning for the most recent flight over that route was done mostly by watching the Weather Channel for a couple of days prior to leaving... Getting a current weather briefing and TFR notices over the route about 5 minutes before launching... On the way out the door glancing at the wall map of the USA and deciding that Chattanoga looked like a good spot to refuel... Climbed in the plane, dialed up the GPS moving map and told it, "take me to KCHA", cruise climbed to 10,500 and away we went... Yes, I did keep a Howie Keefe nav chart open on my lap and a VOR somewhere up ahead tuned in on the radio in case the GPS started leaking magic smoke... And some visual navigation was done, mostly of the , "see there, that's the runways at Dayton" variety, for the passengers amusement... It's a new world and while learning how to plot a track on a nav chart and visually navigate there will be part of early cross country training, immediately after the student demonstrates he can do it one time, the CFI will turn his remaining teaching to the vastly more important issues of managing the glass cockpit... Chatting with a group of newer pilots at an airport in Indiana the topic of NDB approaches came up... Turns out, of 4 IFR pilots in the group, none had ever done an NDB approach... So, on the flight back home I used the NDB receiver as I always do, tuned in the ball game and followed the expressway home - staying to the right, of course... denny |
This question is directed at student pilots and flight instructors. How many of you learn/teach cross country navigation using the traditional methods using paper charts, protractors, E6B and navigation logs? During my training more than 10 years ago, xc planning was a fairly elaborate process that involved filling lots of numbers in small boxes. The flight was broken down into approximately 25 mile legs, and each row had distance, true course, winds, temperature, variation, wind correction angle, magnetic heading, time, fuel. Then we add up the columns to get total time and fuel. We also compute the time required to climb and descent. If we want to be more precise, we also compute the fuel needed for taxi and run-up. Once airborne, we religiously write down more numbers at each checkpoint and recompute ground speed. All fine, but I don't do any of these on a typical flight. I use an online source such as skyvector.com to view the charts. Then I use an online software to compute heading and time. That plus a paper chart is pretty much all I need for a VFR flight. I've been toying with the idea of taking a different approach to teaching flight planning by skipping a lot of these things. I don't see the purpose of doing things by hand when it is done much easier on a computer. It feels like using a typewriter instead of a computer. In addition, the less stuff you have in the cockpit, the simpler the organization becomes. All these papers and pens flying around the cockpit becomes an organizational nightmare. So what are your thoughts on this? Is the ability to compute a flight by hand really important? Are there important aspects I am overlooking? Yes, yes and yes. It's just like mathmatics in school. In the real world you are 99 times out of 100 going to use a calculator but unless you understand the operation you don't really know that what comes out of the calculator is correct. Add to that the the future pilot you are training might end up starting a flight from somewhere that has no computer terminal and all they have is a sectional and E6B. |
Flight Planning PYM to DEN | William Snow | Piloting | 22 | December 12th 05 04:24 PM |
Planning a flight | Chris | Instrument Flight Rules | 23 | February 23rd 05 09:15 PM |
Pre-flight planning really is worth doing. | Roy Smith | Instrument Flight Rules | 6 | August 25th 04 10:17 PM |
Flight planning at the lower flight levels | Peter R. | Piloting | 2 | March 16th 04 02:39 AM |
Flight Planning Software | Joe Allbritten | Piloting | 2 | December 21st 03 02:29 PM |
