#11
In a previous article, Ron Natalie said:
Paul Tomblin wrote: Add 40. Multiply by 9/5 or 5/9 depending on whether you're going F-C or C-F. Subtract 40. Works both ways, exactly. 40? Where does 40 come from? Try it, it works. -40 is where the two values are equal, so essentially you're moving the graph "F versus C" so that it goes through the origin, applying the slope of the line, and then shifting it down again. -40 + 40 = 0 0 * 5/9 = 0 0 - 40 = -40 - -40 F = -40 C 0 + 40 = 40 40 * 5/9 = 22.22 22.222 - 40 = -17.7777 - 0 F = -17.8 C 212 + 40 = 252 252 * 5/9 = 140 140 - 40 = 100 - 212 F = 100 C And so on. -- Paul Tomblin http://xcski.com/blogs/pt/ "Unfortunately, you go to war with the Secretary of Defense you have, not the Secretary of Defense you wish you had." |
Similar Threads | ||||
FS: 1996 "Aircraft Of The World: A Complete Guide" Binder Sheet Singles | J.R. Sinclair | Aviation Marketplace | 0 | July 14th 04 07:34 AM |
FS: 1930's Space Exploration Un-Cut Tatoo Sheet | J.R. Sinclair | Aviation Marketplace | 0 | June 7th 04 06:28 AM |
Corrosion Protection on Alluminum Sheet Aircraft? | DL152279546231 | Home Built | 6 | February 10th 04 05:10 AM |
4130 Chromaloy Sheet Availability | c hinds | Home Built | 1 | January 24th 04 04:17 AM |
Sheet metal shear/press brake | VideoFlyer | Home Built | 7 | October 7th 03 07:08 PM |
