OLC comment, MOP logging deactivated
At 03:48 22 May 2020, kinsell wrote:
On 5/21/20 7:26 PM, wrote: Good day all, before the season start I downloaded the Flarm verion 6.83 and it installed ok. We just started flying and my declaration is in light grey as the OLC system decla Autocomment: Used Aircraft is FES glider, but MOP logging deactivated. I looked in my flarm info and the licences present in my flarm include " ENL ". Any bodie know what this OLC comment refer to Many Thanks in advance and fly safely André Pepin Lak 17b fes 21m " DB " Looking at your file on IGC Webview, it shows no significant ENL readings, just a small amount of noise. Maybe your Flarm isn't picking up the frequencies generated by your motor, or mmaybe the hardware is broken? MOP and ENL are not the same thing. MOP is provided by an external sensor. For FES, it is a current tranformer over the supply wire to the motor, for a Jet it is a suitably filtered noise sensor filtered for jet noise, placed close to the jet pipe. |
To expand upon Tim's note:
ENL = Engine Noise Level MOP = Means of Propulsion IGC does not allow ENL to be used for electric or Jet engines, they must use MOP sensors. ENL may be used for gas powered engines. This is not a new change for the IGC, but I think the OLC has just implemented the change in their software. Many FES owners have been using ENL for years, but it is my understanding that this is no longer allowed by IGC as sufficient proof the FES was not used. |
At 19:23 22 May 2020, Dave Springford wrote:
To expand upon Tim's note: ENL = Engine Noise Level MOP = Means of Propulsion IGC does not allow ENL to be used for electric or Jet engines, they must use MOP sensors. ENL may be used for gas powered engines. This is not a new change for the IGC, but I think the OLC has just implemented the change in their software. Many FES owners have been using ENL for years, but it is my understanding that this is no longer allowed by IGC as sufficient proof the FES was not used. It gets better! The LX MOP2 sensor can only be used with specified LXV Flight Recorders. |
To expand upon Tim's note: ENL = Engine Noise Level MOP = Means of Propulsion IGC does not allow ENL to be used for electric or Jet engines, they must use MOP sensors. ENL may be used for gas powered engines. This is not a new change for the IGC, but I think the OLC has just implemented the change in their software. Many FES owners have been using ENL for years, but it is my understanding that this is no longer allowed by IGC as sufficient proof the FES was not used. Dave, Can you point to a current reference for IGC only allowing MOP sensors for FES please. SC3C says: 11.2ENL figures –engine on An ENL of over 700 is expected when the engine is running at climb power. Over 900 is typical for a two-stroke engine, and over 700 for a nose mounted 4-stroke. Values of 999 have been recorded with a two-stroke engine runningat full power, and over 900 for a Forward Electric System (FES) with the FR close behind it. These high ENLs are produced for a significant time during a climb and can therefore be attributed to engine running. SC3B says: 1.4.2EngineRecordingSystems - General. Enginerecording is by IGCENL and MOP systems that are designed to differentiate between conditions of forward thrust from the engine system, and gliding flight without the use of engine. The low frequency IGC Environmental Noise Level (ENL) system uses a sensor inside the FR and is most sensitive to acoustic noise between100and 200Hz. It was originally designed to record the operation of two-strokepistonengines, but may also record reasonable ENL numbers with Forward Electric Systems (FES) if the FR is installed just behind the engine and its retractible propeller (subject to testing to show this). Where the ENL system does not produce high enough readings with certain types of engine an d FR installations, either the FR location must be changed or an additional sensor under the MOP code must be fitted so that three high MOP numbers are produced in each IGC file fix line in addition to ENL. Difficult cases for Engine recording are in 1.4.2.2- 1.4.2.5 below, and more detailis in SC3Annex C (SC3C) Chapter 11, and Chapter 5 of the FR Specification. Which seems to be saying "Fit a MOP Sensor where ENL is not Satisfactory" it does not seem to be mandating it in all cases. |
On 5/23/20 8:29 AM, Tim Newport-Peace wrote:
At 19:23 22 May 2020, Dave Springford wrote: To expand upon Tim's note: ENL = Engine Noise Level MOP = Means of Propulsion IGC does not allow ENL to be used for electric or Jet engines, they must use MOP sensors. ENL may be used for gas powered engines. This is not a new change for the IGC, but I think the OLC has just implemented the change in their software. Many FES owners have been using ENL for years, but it is my understanding that this is no longer allowed by IGC as sufficient proof the FES was not used. Dave, Can you point to a current reference for IGC only allowing MOP sensors for FES please. SC3C says: 11.2ENL figures –engine on An ENL of over 700 is expected when the engine is running at climb power. Over 900 is typical for a two-stroke engine, and over 700 for a nose mounted 4-stroke. Values of 999 have been recorded with a two-stroke engine runningat full power, and over 900 for a Forward Electric System (FES) with the FR close behind it. These high ENLs are produced for a significant time during a climb and can therefore be attributed to engine running. SC3B says: 1.4.2EngineRecordingSystems - General. Enginerecording is by IGCENL and MOP systems that are designed to differentiate between conditions of forward thrust from the engine system, and gliding flight without the use of engine. The low frequency IGC Environmental Noise Level (ENL) system uses a sensor inside the FR and is most sensitive to acoustic noise between100and 200Hz. It was originally designed to record the operation of two-strokepistonengines, but may also record reasonable ENL numbers with Forward Electric Systems (FES) if the FR is installed just behind the engine and its retractible propeller (subject to testing to show this). Where the ENL system does not produce high enough readings with certain types of engine an d FR installations, either the FR location must be changed or an additional sensor under the MOP code must be fitted so that three high MOP numbers are produced in each IGC file fix line in addition to ENL. Difficult cases for Engine recording are in 1.4.2.2- 1.4.2.5 below, and more detailis in SC3Annex C (SC3C) Chapter 11, and Chapter 5 of the FR Specification. Which seems to be saying "Fit a MOP Sensor where ENL is not Satisfactory" it does not seem to be mandating it in all cases. Current OLC rules, dated Feb 23, say this: " Flights, which are performed with motorized gliders, have to be documented with a recording of the motor's operating time (ENL).. For aircraft with too low noise level, for example all aircraft with a front electric sustainer (FES), the MOP level must be recorded in addition to above." I just looked at a self-launching twin jet glider, its ENL values during the launch were only about 100. Wonder if OLC is going to be enforcing MOP for jets also? |
Hi Tim,
Sorry, I paraphrased too briefly, but the net effect of the code is that FES typically doesn't meet the noise threshold and that MOP is therefore necessary, per your last statement. As Eric asked above, will ENL "hear" an FES that is running at low enough power to double your L/D or reduce your sink rate in a thermal? Anecdotal evidence suggests that it can not and some electric engine gliders have been seen assisting themselves with power that is not being recorded in an IGC file by ENL. However, thanks to @kinsell for reading the OLC rules we now know why OLC is rejecting FES claims without MOP. |
At 15:31 23 May 2020, Dave Springford wrote:
Hi Tim, Sorry, I paraphrased too briefly, but the net effect of the code is that FES typically doesn't meet the noise threshold and that MOP is therefore necessary, per your last statement. As Eric asked above, will ENL "hear" an FES that is running at low enough power to double your L/D or reduce your sink rate in a thermal? Anecdotal evidence suggests that it can not and some electric engine gliders have been seen assisting themselves with power that is not being recorded in an IGC file by ENL. However, thanks to @kinsell for reading the OLC rules we now know why OLC is rejecting FES claims without MOP. I very much suspect that the ENL values with a FES are dependent on where the recorder is mounted. If it is close to the engine then ENL may be satisfactory, but if it is panel-mounted then maybe not so. Good news for the two LX companies however as I believe they are the only manufacturers of MOP boxes. |
I flew with an FES and an LX9000 with regular ENL logging today, and I can confirm even on minimum power the FES is clearly visible on the trace ENL. It's electric, but it's far from silent, and louder than any cockpit source of noise.
On 5/23/20 9:31 AM, Dave Springford wrote:
Hi Tim, Sorry, I paraphrased too briefly, but the net effect of the code is that FES typically doesn't meet the noise threshold and that MOP is therefore necessary, per your last statement. As Eric asked above, will ENL "hear" an FES that is running at low enough power to double your L/D or reduce your sink rate in a thermal? Anecdotal evidence suggests that it can not and some electric engine gliders have been seen assisting themselves with power that is not being recorded in an IGC file by ENL. However, thanks to @kinsell for reading the OLC rules we now know why OLC is rejecting FES claims without MOP. And now, by some miracle, Andre is getting credit for his flight on the 21st. In fact double credit, as the flight was submitted twice. It's easy to delete flights if you need to resubmit, but only within the two day time limit. |
At 14:14 24 May 2020, kinsell wrote:
On 5/23/20 9:31 AM, Dave Springford wrote: Hi Tim, Sorry, I paraphrased too briefly, but the net effect of the code is that FES typically doesn't meet the noise threshold and that MOP is therefore necessary, per your last statement. As Eric asked above, will ENL "hear" an FES that is running at low enough power to double your L/D or reduce your sink rate in a thermal? Anecdotal evidence suggests that it can not and some electric engine gliders have been seen assisting themselves with power that is not being recorded in an IGC file by ENL. However, thanks to @kinsell for reading the OLC rules we now know why OLC is rejecting FES claims without MOP. And now, by some miracle, Andre is getting credit for his flight on the 21st. In fact double credit, as the flight was submitted twice. It's easy to delete flights if you need to resubmit, but only within the two day time limit. I just love a Happy Ending... |
Similar Threads | ||||
Without comment | bildan | Soaring | 2 | July 1st 11 10:23 AM |
A Random Comment | birdog[_2_] | Piloting | 33 | June 3rd 10 05:31 AM |
jouer gratuit , comment devenir follement riche , jouer au monopolygratuitement en ligne , comment gagner l argent internet , jeux en lignegratuits , jeux gratuits , jouer gratuitement sims , comment devenir riche a, jouer gratuitement , gagner | [email protected] | Piloting | 0 | May 12th 09 11:37 AM |
Military Command Deactivated | Otis Willie | Naval Aviation | 2 | January 10th 06 02:11 PM |
No comment | Greasy Rider @ invalid.com | Simulators | 0 | December 9th 05 12:21 AM |
