#71
(USA) NTSB issues recommendations to the FAA and the SSA regardingtransponder use in gliders
Mike Schumann wrote:
The failure to provide separation services between VFR and IFR traffic is the way the system has been run since day one. The rules haven't been changed to account for increases in aircraft speed and traffic density. VFR altitude encoders, while not meeting the standards of IFR systems designed for reduced separation environments, still have to meet FAA standards. Any lack of accuracy should be reflected in the separation provide to the IFR traffic. My understanding is it's not the lack of basic accuracy of the encoders, but the lack of confirmation that the encoder is working properly. An IFR aircraft is in contact with ATC, and ATC knows it's altimeter and encoder show the same pressure altitude. ATC is not in contact with the VFR aircraft, and can not do this cross-check of the altimeter and encoder readings. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#72
(USA) NTSB issues recommendations to the FAA and the SSA regarding transponder use in gliders
So just because there is a chance that the encoder on a VFR aircraft is not
working, you go ahead and let an IFR aircraft head right towards the target??? That certainly doesn't make sense. If there is a legitimate concern that the VFR encoder is not accurate, the logical conclusion would be to make sure you have extra separation vertically between the IFR aircraft than you otherwise might. Mike Schumann "Eric Greenwell" wrote in message news:_SUgk.205$oU.75@trnddc07... Mike Schumann wrote: The failure to provide separation services between VFR and IFR traffic is the way the system has been run since day one. The rules haven't been changed to account for increases in aircraft speed and traffic density. VFR altitude encoders, while not meeting the standards of IFR systems designed for reduced separation environments, still have to meet FAA standards. Any lack of accuracy should be reflected in the separation provide to the IFR traffic. My understanding is it's not the lack of basic accuracy of the encoders, but the lack of confirmation that the encoder is working properly. An IFR aircraft is in contact with ATC, and ATC knows it's altimeter and encoder show the same pressure altitude. ATC is not in contact with the VFR aircraft, and can not do this cross-check of the altimeter and encoder readings. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org ** Posted from http://www.teranews.com ** |
#73
(USA) NTSB issues recommendations to the FAA and the SSAregarding transponder use in gliders
On Jul 21, 6:14*am, "Mike Schumann" mike-nos...@traditions-
nospam.com wrote: *If there is a legitimate concern that the VFR encoder is not accurate, the logical conclusion would be to make sure you have extra separation vertically between the IFR aircraft than you otherwise might. In a system where the transponder and encoder are separate units, the encoder to transponder altitude interface is typically implemented by multiple ground/open discretes. Something as simple as a dirty contact may result in a discrete being assumed open instead of ground state. A single bit error may result in an encoder reporting an altitude several thousands of feet in error. The Gilham Grey code used for altitude encoders has no parity check and, with few exceptions, no other means of error checking except correlation with the pilot's altitude report. One exception is transponders that display the reported altitude and allow the pilot to check it. Nevertheless the controller has no way to know the reported altitude is accurate unless verified against a pilot altitude report. In this context accurate does not mean plus/minus 200 feet (the resolution is only 100ft) but perhaps plus/minus 5000ft or more. Of course the same non error checked, low integrity, transponder/ encoder systems are the basis for TCAS conflict resolution. ref http://www.airsport-corp.com/dot_faa_ct-97_7.pdf "The results of this study indicate that most of the transponders carried by GA aircraft fail to meet all of the performance criteria specified in national standards documents, and that a number of these failures may be serious enough to significantly affect their performance with secondary surveillance radar systems and TCAS collision avoidance equipment. In addition, the data showed that performance failures on key transponder parameters were unrelated to the time that had elapsed since a transponder had received its last biennial inspection." Anyone ready for ADS-B yet. Andy |
#74
ADS-B is definitely the way to go. But this ignores the most basic problem,
which is that the FAA is ignoring the data that they already have. Even if they get have VFR ADS-B target that they know is accurate, their current procedure is to give the IFR traffic an advisory, but generally not any deviation to avoid the known traffic. Mike Schumann "Andy" wrote in message ... On Jul 21, 6:14 am, "Mike Schumann" mike-nos...@traditions- nospam.com wrote: If there is a legitimate concern that the VFR encoder is not accurate, the logical conclusion would be to make sure you have extra separation vertically between the IFR aircraft than you otherwise might. In a system where the transponder and encoder are separate units, the encoder to transponder altitude interface is typically implemented by multiple ground/open discretes. Something as simple as a dirty contact may result in a discrete being assumed open instead of ground state. A single bit error may result in an encoder reporting an altitude several thousands of feet in error. The Gilham Grey code used for altitude encoders has no parity check and, with few exceptions, no other means of error checking except correlation with the pilot's altitude report. One exception is transponders that display the reported altitude and allow the pilot to check it. Nevertheless the controller has no way to know the reported altitude is accurate unless verified against a pilot altitude report. In this context accurate does not mean plus/minus 200 feet (the resolution is only 100ft) but perhaps plus/minus 5000ft or more. Of course the same non error checked, low integrity, transponder/ encoder systems are the basis for TCAS conflict resolution. ref http://www.airsport-corp.com/dot_faa_ct-97_7.pdf "The results of this study indicate that most of the transponders carried by GA aircraft fail to meet all of the performance criteria specified in national standards documents, and that a number of these failures may be serious enough to significantly affect their performance with secondary surveillance radar systems and TCAS collision avoidance equipment. In addition, the data showed that performance failures on key transponder parameters were unrelated to the time that had elapsed since a transponder had received its last biennial inspection." Anyone ready for ADS-B yet. Andy ** Posted from http://www.teranews.com ** |
#75
ADS-B is definitely the way to go. But this ignores the most basic problem, which is that the FAA is ignoring the data that they already have. The FAA isn't ignoring any data, they just aren't using it the way you think they should. They do give the information to the IFR pilot, who can request a new vector if the pilot thinks the present one is unsafe. You aren't getting the detailed reasoning or procedures from RAS that you seem to be looking for, so I suggest you discuss the situation with a controller as the next step. That should get you the procedures, but not necessarily the reasoning, for which you will likely have to dig further. Practically speaking, the current procedures seem to work well. If you, as a transponder equipped VFR pilot, want to improve upon them, you can contact ATC so they can confirm your altitude. You can also request flight following. Contacting ATC will usually help even if you are not transponder equipped. Even if they get have VFR ADS-B target that they know is accurate, their current procedure is to give the IFR traffic an advisory, but generally not any deviation to avoid the known traffic. We are at the beginning of the transition to ADS-B. The procedures will change as it's use expands, and I don't think even the FAA knows what the detailed procedures will be 10 or 20 years from now, but no one suggests they will the same. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#76
We are at the beginning of the transition to ADS-B. The procedures will change as it's use expands, and I don't think even the FAA knows what the detailed procedures will be 10 or 20 years from now, but no one suggests they will the same. -- Eric Greenwell - Washington State, USA When is ADS-B going to be implimented? Do you think it will be any better for gliders from the power/size/ cost standpoint? Perhaps the FAA /SSA can help fund/steer development of ADS-B for use in gliders to meet our specific limitations and concede on some points for Gliders not using them below some agreed upon altitude to conserve power. It could simply be desinged to turn on automatically at the preset altitude. Im sure we could get these things made to mil spec by some Chineese company at a greatly reduced price. Ray |
#77
On Jul 22, 2:14*pm, jb92563 wrote:
Perhaps the FAA /SSA can help fund/steer development of ADS-B for use in gliders Your questions are answered in this month's and last (or a bit older) month's issues of Soaring. -Tom |
#79
The reason that we are getting all of these TCAS advisories is because we are relying on see and be seen for IFR traffic to avoid VFR aircraft, instead of having ATC automatically vector IFR traffic around known targets. Mike, Are you just venting, or are you willing and able to offer a suggestion about how that could be done? Jack |
Similar Threads | ||||
(USA) NTSB issues recommendations to the FAA and the SSA regardingtransponder use in gliders | Sarah Anderson[_2_] | Soaring | 6 | April 1st 08 12:51 PM |
go to NTSB.GOV | [email protected] | Piloting | 0 | August 15th 05 08:34 PM |
FAA-NTSB | [email protected] | Piloting | 4 | January 25th 05 01:34 PM |
NTSB | EDR | Piloting | 22 | July 2nd 04 03:03 AM |
NTSB 830.5 & 830.15? | Mike Noel | Owning | 2 | July 8th 03 05:51 AM |
