Transponder antenna - blade vs stub monopole
Is there a downside to mounting on a ground plane inside the fuselage
of a non-carbon glass glider? |
Hi,
I was thinking the same thing. I believe that a ground plane would be useless inside a carbon fiber glider. However, the same is true for any other type of transponder antenna. They all should have a good ground plane. Paul Remde "brianDG303" wrote in message ... Is there a downside to mounting on a ground plane inside the fuselage of a non-carbon glass glider? |
Not all transponder antennas need a ground plane, only monopoles do. I
use the L-2 dipole antenna on this page: http://www.advancedaircraft.com/ inside my fiberglass ASW-19 tail cone. It works great with my Becker ATC 4401-175 and was very easy to install. -John Paul Remde wrote: Hi, I was thinking the same thing. I believe that a ground plane would be useless inside a carbon fiber glider. However, the same is true for any other type of transponder antenna. They all should have a good ground plane. Paul Remde "brianDG303" wrote in message ... Is there a downside to mounting on a ground plane inside the fuselage of a non-carbon glass glider? |
On Jun 13, 1:08*pm, "Paul Remde" wrote:
Hi, I was thinking the same thing. *I believe that a ground plane would be useless inside a carbon fiber glider. *However, the same is true for any other type of transponder antenna. *They all should have a good ground plane. Paul Remde "brianDG303" wrote in message ... Is there a downside to mounting on a ground plane inside the fuselage of a non-carbon glass glider? Antenna vendors or glider manufactuers will often want you to back the carbon fiber fuselage where the antenna is mounted with an adhesive aluminum foil or thin plate - mostly for purposes of good contact with the outer (ground) parts of the antenna. Follow the glider manufacturer and antenna vendors instructions. Schleicher certainly show such a plate used on the ASH-26E. They also specify a rod transponder antenna. No idea why. Maybe easier to physically mount (no concerns about surface curvature, etc.). Personally I'll eat my hat if anybody could ever measure the drag difference between a rod and streamlined antenna. Darryl Darryl Darryl |
In article brianDG303 writes:
Is there a downside to mounting on a ground plane inside the fuselage of a non-carbon glass glider? Since the ground plane should extend at least 23 inches in each direction around the antenna, it is probably hard to get that inside the glider. One that extends front and back but is more limited to the sides (perhaps wrapping around inside) probably would work, but would be a bit reduced from a full ground plane. Alan |
Alan wrote:
In article brianDG303 writes: Is there a downside to mounting on a ground plane inside the fuselage of a non-carbon glass glider? Since the ground plane should extend at least 23 inches in each direction around the antenna, it is probably hard to get that inside the glider. 23 inch radius for a quarter-wave antenna? Most installations I've seen use no more than a 3 inch radius ground plane... |
The 23" is for a 1/4 wave antenna at the frequency for the aviation radio
band (123 MHz). The transponder operates at about 1,000 MHz, so a 1/4 wave is much smaller. You do not even need to do much calculation, since the radius of the ground plane should be equal to the height of the antenna. So, the diameter would be twice the antenna height. The shape need not be round. It can be square or rectangular. Generlaly, a slight improvement will be achieved with a larger ground plane. Also remember, that, even though the transmitter is pulsed at a very short duration, there could be some possible danger having it close to your body. If you use the ground plane to "hide" the antenna from you, there would be little danger from exposure. The jury is still out on this one. I do not think there is any credible evidence of a danger, but I would not expose myself unless there was no other choice. Mine is mounted under my seat, upside down. Upside down is better because radio waves at this frequency are "line of sight" and the ground stations interrogating you are all below you. Do a good job of coax installation. I have seen some crappy jobs. Also remember that coax attenuation at 1,000 MHz with RG-58 is very high - so keep the run short. Colin Lamb |
wrong! A ground plane should have a radius of at least 1/4 wavelength of the
antenna's operating frequency, a 23" antenna ground plane then would be about right for a VHF airband communication antenna (118-136 mhz) and in gliders this is seldom possible so use what you can get.. Transponder antenna ground planes are typically recommended to be 6" diameter. These are ideal....but not always possible so use what you can, too large isn't a problem but performance can degrade from the ideal as it becomes smaller. tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Alan" wrote in message ... In article brianDG303 writes: Is there a downside to mounting on a ground plane inside the fuselage of a non-carbon glass glider? Since the ground plane should extend at least 23 inches in each direction around the antenna, it is probably hard to get that inside the glider. One that extends front and back but is more limited to the sides (perhaps wrapping around inside) probably would work, but would be a bit reduced from a full ground plane. Alan |
I installed a blade antenna in the recommended location for my Discus
2 just behind and to one side of the gear door and an internal ground plane about 6" square. It works very well in this location (also had a short coax from the transponder, which is a consideration at these higher frequencies). Tim is absolutely right, though. It is physically a right royal pain in the ass. I don't know anyone who has one in this location who hasn't broken it as it is perfectly located to snag on the trailer ramp. I have a short quarter wave monopole as back-up. This will be my default the next time the blade breaks! I doubt that the extra drag is worth worrying about. If you can locate the blade above and behind the cockpit, this is a much safer location and I have seen a couple of these installations that also work well. Mike |
Alan wrote:
In article brianDG303 writes: Is there a downside to mounting on a ground plane inside the fuselage of a non-carbon glass glider? Since the ground plane should extend at least 23 inches in each direction around the antenna, it is probably hard to get that inside the glider. That sounds like a dimension for the aircraft communication radio, working in the 120-130 mhz range. The transponder uses 1090 mhz, about 10 times higher. That indicates a 2.3" radius ground plane would be adequate, or the 6" diameter Marc points out as commonly used. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Similar Threads | ||||
Transponder Antenna | Rick Fuller | Soaring | 6 | January 30th 08 06:03 PM |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Oil on transponder antenna | Bob | Owning | 12 | May 9th 04 08:59 PM |
Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 03:32 AM |
Blade type VHF antenna? | JFLEISC | Home Built | 6 | December 13th 03 04:28 AM |
