Oil on transponder antenna
Old May 2nd 04, 11:34 PM
Bob
Default Oil on transponder antenna
Is it possible that some oil on the transponder antenna would cause it
to transmit intermittently?
I would have wiped it clean and tried it out but it's 5 OVC today....
Thanx
Old May 3rd 04, 12:46 AM
rip
Yes it is. Before I got an air/oil separator that actually worked, my
transponder was very unreliable unless I kept the antenna clean.
Thanx
Old May 3rd 04, 02:47 AM
Tom Jackson
For what its worth, I also had an intermittant transponder, and finally
concluded that it was due to the coax cable getting damaged by the heat in
the heater duct.
In my Warrior, the coax routes down through the heater ductwork to the belly
of the plane. Every winter, I would experience transponder trouble. I
finally insulated the antenna wire, and now there are no more problems.
"Bob" wrote in message
Thanx
Old May 3rd 04, 04:19 PM
Bob Chilcoat
Interesting, I just posted the same question on RAP. See
"Pinging Jim Wier - X-Ponder Antenna Question"
Bob (Chief Pilot, White Knuckle Airways)
I don't have to like Bush and Cheney to love America
(Or Kerry, for that matter)
Thanx
Old May 3rd 04, 05:23 PM
MikeM
Thanx
No!
Oil is a pretty good insulator. Oil is used as a coolant in transformers.
It is used to conduct heat away from the non-inductive resistor in a 1Ghz Bird
wattmeter/dummy load that I own.
If your transponder is intermittent, then there is about a 0.1% probability
that wiping the antenna will fix it...
MikeM
Old May 3rd 04, 06:54 PM
Thanx
No!
MikeM
Clean oil is an insulator.
An oil film with who knows what gunk in it is not such a good insulator.
So, if you change the oil on your antenna regularly...
Jim Pennino
Remove -spam-sux to reply.
Old May 4th 04, 02:13 AM
John
A film of oil with some dirt attached is still transparent to the RF.
HOWEVER if you wipe the antenna that is attached to a thin skinned
aircraft you will MOVE the antenna slightly. Maybe just enough to
restore connection in the rusty connector joint or the broken solder
joint.
Wiping works just not for the reason stated.
JF
Nevertheless, I stand by my statement.
In order for dirty oil to effect the transmission, it would have to
carbonize the oil into a conductive track shorting across the insulator
at the base of the monopole. The peak power output from the transponder
is about about 250W, which puts about SQR(250*50)=~110V across the
antenna base.
A little dirty oil will not arc over at 100V!
MikeM
VHF & Transponder antenna Steve Home Built 1 December 6th 04 05:29 PM
Spare Transponder Antenna? Jim Weir Home Built 6 May 25th 04 04:34 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 02:10 PM
Transponder Antenna Question Jay Honeck Owning 10 December 29th 03 05:40 PM
Wanted: Transponder antenna Grandpa B. Home Built 22 November 28th 03 09:03 AM
