Looking for a technical term
Old September 28th 09, 07:15 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
Default Looking for a technical term
Is there a term for the difference between the angle of incidence of the
wing and the angle of incidence of the tailplane? I have heard/read
decalage used this way; however, wikipedia says decalage means the
difference between the angles of incidence between the two wings of a
bi-plane. (Thinking of that makes me think that extending Fowler flaps
turns the aircraft into a bi-plane).
Is there a separate term? Is this usage correct (Is Wikipedia just
incomplete?)?
Old September 28th 09, 07:35 PM posted to rec.aviation.soaring
Mike Bamberg
wing and the angle of incidence of the tailplane? *I have heard/read
bi-plane. *(Thinking of that makes me think that extending Fowler flaps
turns the aircraft into a bi-plane). *
Is there a separate term? *Is this usage correct (Is Wikipedia just
incomplete?)?
Normally the angle of incidence is relative to a datum reference on
the fuselage. The wing is usually described as a positive angle (if
the leading edge is raised above the trailing edge of the chord) and
the tailplane is a negative (if the leading edge is down relative to
the trailing edge).
The angle of decalage is usually described as the relative angle
between the chord line of the wing and the chordline of the tailplane
(or other surface). No reference to the fuselage datum is made.
Old September 28th 09, 07:39 PM posted to rec.aviation.soaring
[email protected][_2_]
incomplete?)?
Looks like Wikipedia is incomplete. Decalage between wing and tail is
used to generate pitch stability.
Take a look at http://www.av8n.com/how/htm/aoastab.html, it has a good
explanation.
Kirk
Old September 28th 09, 09:00 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
Thanks for the reference. I just wanted to be sure of the usage. I agreed
with everything in the explanation except the pronunciation of the word,
but that is hard to do without offering a full graduate course in
phonetics.
I'm happy to have the article to support my arguments about turning
flight.
At 18:39 28 September 2009, wrote:
wing and the angle of incidence of the tailplane? =A0I have heard/read
bi-plane. =A0(Thinking of that makes me think that extending Fowler
flaps
turns the aircraft into a bi-plane). =A0
Is there a separate term? =A0Is this usage correct (Is Wikipedia just
incomplete?)?
Take a look at
explanation.
Kirk
Old September 28th 09, 09:21 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On 28 Sep 2009 18:15:03 GMT, Nyal Williams
incomplete?)?
Yes, Wikipedia is incomplete. Decalage can refer to a difference in
incidence angle between any two aerodynamic surfaces.
rj
Old September 29th 09, 06:46 AM posted to rec.aviation.soaring
Mark Jardini
I have also heard it referred to as "longitudinal dihedral".
Old September 29th 09, 04:00 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
That's funny!
Daley to run for 6th Mayoral term A Guy Called Tyketto Piloting 4 December 31st 06 08:19 PM
Long term storage JSBOUGHER Owning 19 October 18th 06 11:49 AM
First use of term "sailplane" ? Ken Kochanski (KK) Soaring 9 February 6th 05 12:59 PM
The term "Fighter" Prowlus Military Aviation 23 December 28th 03 11:01 AM
Aeronautical Term Nyal Williams Restoration 1 August 4th 03 09:33 PM
