X Plane Brakes
Old October 10th 09, 06:31 PM posted to rec.aviation.simulators
Pat Dotson
Default X Plane Brakes
I have the latest version of X Plane. Why won't the brakes stop the
plane? Flying the default Cessna, I can set down as slowly and early
as possible and still roll right off the end of the runway. Tried
both "regular strength" and "max strength" brake application.
Old October 26th 09, 01:56 PM posted to rec.aviation.simulators
raamman
On Oct 10, 1:31*pm, Pat Dotson wrote:
I have the latest version of X Plane. *Why won't the brakes stop the
plane? *Flying the default Cessna, I can set down as slowly and early
as possible and still roll right off the end of the runway. *Tried
what key or axis to you have the command bound to ? if, for example,
you bound it to the "B" key on your keypad you might want to check if
it is remaining active after you press, or it might be a momentary
engagement which would explain why you keep going.
Old December 5th 09, 04:54 AM posted to rec.aviation.simulators
PJ
Sorry Pat can't help U but would You know where the microsoft flight
newsgroup went to
Thanks
Hot brakes Denny Piloting 2 November 20th 08 04:19 PM
Brakes? WingFlaps Piloting 69 March 4th 08 06:27 AM
Carbon brakes [email protected] Piloting 3 August 19th 06 07:01 AM
Cobratrailer&brakes Greg Arnold Soaring 5 October 6th 03 03:14 PM
rotor brakes Bill Chernoff Rotorcraft 5 September 5th 03 11:14 PM
